Datasheet Texas Instruments SN74LVCH16373ADGGR — Даташит
СерияSN74LVCH16373A
МодельSN74LVCH16373ADGGR
16-битная прозрачная защелка типа D с выходами с 3 состояниями 48-TSSOP от -40 до 125
SN74LVCH16373A 16-Bit Transparent D-Type Latch With 3-State Outputs datasheet
PDF, 960 Кб, Версия: N, Файл опубликован: 24 июл 2014
47 предложений от 19 поставщиков
Микросхема Логический замок, 16Bit Transparent D-Type Latch With 3-State Outputs 48-TSSOP -40℃ to 125℃
SN74LVCH16373ADGGR
от 16 ₽
SN74LVCH16373ADGGR
62 ₽
SN74LVCH16373ADGGR
62 ₽
Hi-Tech Circuit Group
SN74LVCH16373ADGGR
Pin48
Package TypeDGG
Industry STD TermTSSOP
Package QTY2000
МаркировкаLVCH16373A
Width (мм)6.1
Length (мм)12.5
Thickness (мм)1.15
Pitch (мм).5
Max Height (мм)1.2
3-State OutputYes
Bits16
F @ Nom Voltage(Max)100 Mhz
ICC @ Nom Voltage(Max)0.02 мА
Output Drive (IOL/IOH)(Max)24/-24 мА
Package GroupTSSOP
Package Size: mm2:W x L48TSSOP: 101 mm2: 8.1 x 12.5(TSSOP) PKG
Schmitt TriggerNo
Technology FamilyLVC
VCC(Max)3.6 В
VCC(Min)1.65 В
Voltage(Nom)1.8,2.5,2.7,3.3 В
tpd @ Nom Voltage(Max)4.9,4.2 нс
  • Bus-Hold Circuit
    PDF, 418 Кб, Файл опубликован: 5 фев 2001
    When designing systems that include CMOS devices, designers must pay special attention to the operating condition in which all of the bus drivers are in an inactive, high-impedance condition (3-state). Unless special measures are taken, this condition can lead to undefined levels and, thus, to a significant increase in the device?s power dissipation. In extreme cases, this leads to oscillation of
  • Semiconductors > Logic > Flip-Flop/Latch/Register > D-Type Latch
На английском языке: Datasheet Texas Instruments SN74LVCH16373ADGGR
