Datasheet Texas Instruments SN74LVT8980ADWRG4 — Даташит
СерияSN74LVT8980A
МодельSN74LVT8980ADWRG4
Встроенные контроллеры тестовой шины IEEE STD 1149.1 (JTAG) Ведущие устройства TAP с 8-битными универсальными хост-интерфейсами 24-SOIC от -40 до 85
SN54LVT8980A, SN74LVT8980A datasheet
PDF, 865 Кб, Версия: B, Файл опубликован: 18 мар 2004
Микросхема Логический чип, Embedded Test-Bus Controllers IEEE STD 1149.1 (JTAG) TAP Masters W/ 8Bit Generic Host Interfaces 24-SOIC -40℃ to 85℃...
Рутоника
SN74LVT8980ADWRG4
592 ₽
SN74LVT8980ADWRG4
772 ₽
SN74LVT8980ADWRG4
от 1 193 ₽
SN74LVT8980ADWRG4
Pin24
Package TypeDW
Package QTY2000
МаркировкаLVT8980A
Width (мм)7.5
Length (мм)15.4
Thickness (мм)2.35
Max Height (мм)2.65
Bits8
Output Drive (IOL/IOH)(Max)64/-32 мА
Package Size: mm2:W x L24SOIC: 160 mm2: 10.3 x 15.5(SOIC) PKG
Technology FamilyLVT
VCC(Max)3.6 В
VCC(Min)2.7 В
tpd @ Nom Voltage(Max)30 нс
  • Programming CPLDs Via the 'LVT8986 LASP
    PDF, 819 Кб, Файл опубликован: 1 ноя 2005
    This application report summarizes key information required for understanding the 'LVT8986 linking addressable scan ports (LASPs) multidrop addressable IEEE Std 1149.1 (JTAG) test access port (TAP) transceiver. This report includes information about the 'LVT8986 secondary TAPs, bypass and linking shadow protocol, scan-path description languages, serial vector format files, and an example of how to
  • LVT Family Characteristics (Rev. A)
    PDF, 98 Кб, Версия: A, Файл опубликован: 1 мар 1998
    To address the need for a complete low-voltage interface solution, Texas Instruments has developed a new generation of logic devices capable of mixed-mode operation. The LVT series relies on a state-of-the-art submicron BiCMOS process to provide up to a 90% reduction in static power dissipation over ABT. LVT devices solve the system need for a transparent seam between the low-voltage and 5-V secti
  • LVT-to-LVTH Conversion
    PDF, 84 Кб, Файл опубликован: 8 дек 1998
    Original LVT devices that have bus hold have been redesigned to add the High-Impedance State During Power Up and Power Down feature. Additional devices with and without bus hold have been added to the LVT product line. Design guidelines and issues related to the bus-hold features, switching characteristics, and timing requirements are discussed.
Серия: SN74LVT8980A (3)
  • Semiconductors > Logic > Specialty Logic > Boundary Scan (JTAG) Logic
На английском языке: Datasheet Texas Instruments SN74LVT8980ADWRG4
