Datasheet Texas Instruments V62/03668-01XE — Даташит
СерияSN74LVT8980A-EP
МодельV62/03668-01XE
Усовершенствованный продукт Контроллеры встроенной тестовой шины Ieee Std 1149.1 (Jtag) Tap Masters 24-SOIC от -40 до 85
SN74LVT8980A-EP datasheet
PDF, 830 Кб, Версия: A, Файл опубликован: 29 окт 2003
Pin24
Package TypeDW
Package QTY2000
МаркировкаLVT8980AEP
Width (мм)7.5
Length (мм)15.4
Thickness (мм)2.35
Max Height (мм)2.65
Bits8
ICC @ Nom Voltage(Max)7 мА
Тип входаTTL/CMOS
Output Drive (IOL/IOH)(Max)64/-32 мА
Тип выходаLVTTL
Package Size: mm2:W x L24SOIC: 160 mm2: 10.3 x 15.5(SOIC) PKG
RatingHiRel Enhanced Product
Technology FamilyLVT
VCC(Max)3.6 В
VCC(Min)2.7 В
tpd @ Nom Voltage(Max)30 нс
  • LVT Family Characteristics (Rev. A)
    PDF, 98 Кб, Версия: A, Файл опубликован: 1 мар 1998
    To address the need for a complete low-voltage interface solution, Texas Instruments has developed a new generation of logic devices capable of mixed-mode operation. The LVT series relies on a state-of-the-art submicron BiCMOS process to provide up to a 90% reduction in static power dissipation over ABT. LVT devices solve the system need for a transparent seam between the low-voltage and 5-V secti
  • LVT-to-LVTH Conversion
    PDF, 84 Кб, Файл опубликован: 8 дек 1998
    Original LVT devices that have bus hold have been redesigned to add the High-Impedance State During Power Up and Power Down feature. Additional devices with and without bus hold have been added to the LVT product line. Design guidelines and issues related to the bus-hold features, switching characteristics, and timing requirements are discussed.
Серия: SN74LVT8980A-EP (2)
  • Semiconductors > Space & High Reliability > Logic Products > Specialty Logic Products > Boundary Scan (JTAG)
V62/0366801XE, V62/03668 01XE
На английском языке: Datasheet Texas Instruments V62/03668-01XE
Публикации по теме
