Datasheet Texas Instruments SN74LVT8980A-EP — Даташит
СерияSN74LVT8980A-EP
Усовершенствованный продукт Встраиваемые контроллеры тестовой шины Ieee Std 1149.1 (Jtag) Tap Masters
SN74LVT8980A-EP datasheet
PDF, 830 Кб, Версия: A, Файл опубликован: 29 окт 2003
Специальные функциональные логические элементы Mil Enhance Embedded Test-Bus Cntrlr
TradeElectronics
SN74LVT8980A
SN74LVT8980AIDWREPV62/03668-01XE
N12
Pin2424
Package TypeDWDW
Industry STD TermSOICSOIC
JEDEC CodeR-PDSO-GR-PDSO-G
Package QTY20002000
CarrierLARGE T&RLARGE T&R
МаркировкаLVT8980AEPLVT8980AEP
Width (мм)7.57.5
Length (мм)15.415.4
Thickness (мм)2.352.35
Pitch (мм)1.271.27
Max Height (мм)2.652.65
Parameters / ModelsSN74LVT8980AIDWREP
SN74LVT8980AIDWREP
V62/03668-01XE
V62/03668-01XE
Bits88
ICC @ Nom Voltage(Max), мА77
Тип входаTTL/CMOSTTL/CMOS
Рабочий диапазон температур, Cот -40 до 85от -40 до 85
Output Drive (IOL/IOH)(Max), мА64/-3264/-32
Тип выходаLVTTLLVTTL
Package GroupSOICSOIC
Package Size: mm2:W x L, PKG24SOIC: 160 mm2: 10.3 x 15.5(SOIC)24SOIC: 160 mm2: 10.3 x 15.5(SOIC)
RatingHiRel Enhanced ProductHiRel Enhanced Product
Technology FamilyLVTLVT
VCC(Max), В3.63.6
VCC(Min), В2.72.7
tpd @ Nom Voltage(Max), нс3030
RoHSСовместимСовместим
  • LVT Family Characteristics (Rev. A)
    PDF, 98 Кб, Версия: A, Файл опубликован: 1 мар 1998
    To address the need for a complete low-voltage interface solution, Texas Instruments has developed a new generation of logic devices capable of mixed-mode operation. The LVT series relies on a state-of-the-art submicron BiCMOS process to provide up to a 90% reduction in static power dissipation over ABT. LVT devices solve the system need for a transparent seam between the low-voltage and 5-V secti
  • LVT-to-LVTH Conversion
    PDF, 84 Кб, Файл опубликован: 8 дек 1998
    Original LVT devices that have bus hold have been redesigned to add the High-Impedance State During Power Up and Power Down feature. Additional devices with and without bus hold have been added to the LVT product line. Design guidelines and issues related to the bus-hold features, switching characteristics, and timing requirements are discussed.
Серия: SN74LVT8980A-EP (2)
  • Semiconductors> Space & High Reliability> Logic Products> Specialty Logic Products> Boundary Scan (JTAG)
На английском языке: Datasheet Texas Instruments SN74LVT8980A-EP
Публикации по теме
