Линейка продуктов KEEN SIDE
Datasheet Texas Instruments SN74LVT8986ZGV — Даташит
СерияSN74LVT8986
МодельSN74LVT8986ZGV
3,3 В, связывающие адресные порты сканирования, многоточечный адресный приемопередатчик IEEE STD 1149.1 (JTAG) 64-BGA MICROSTAR от -40 до 85
3.3-V Linking Addressable Scan Ports Multidrop-Addressable IEEE STD 1149.1 (JTAG datasheet
PDF, 905 Кб, Версия: E, Файл опубликован: 14 май 2007
Pin64
Package TypeZGV
Industry STD TermBGA MICROSTAR
JEDEC CodeS-PBGA-N
Package QTY348
CarrierJEDEC TRAY (5+1)
МаркировкаLVT8986
Width (мм)8
Length (мм)8
Thickness (мм).9
Pitch (мм).8
Max Height (мм)1.4
  • Cascading Multiple Linking Addressable Scan Port Devices
    PDF, 216 Кб, Файл опубликован: 5 ноя 2002
    This application report is intended to illustrate the capability of cascading multiple Texas Instruments (TI) linking addressable scan port (LASP) devices. It explains configuring the secondary test access ports (TAPs) of cascaded LASPs with the help of a single linking shadow protocol and protocol-bypass inputs. Several examples of linking shadow protocol, along with timing requirements and scan
  • Programming CPLDs Via the 'LVT8986 LASP
    PDF, 819 Кб, Файл опубликован: 1 ноя 2005
    This application report summarizes key information required for understanding the 'LVT8986 linking addressable scan ports (LASPs) multidrop addressable IEEE Std 1149.1 (JTAG) test access port (TAP) transceiver. This report includes information about the 'LVT8986 secondary TAPs, bypass and linking shadow protocol, scan-path description languages, serial vector format files, and an example of how to
  • LVT Family Characteristics (Rev. A)
    PDF, 98 Кб, Версия: A, Файл опубликован: 1 мар 1998
    To address the need for a complete low-voltage interface solution, Texas Instruments has developed a new generation of logic devices capable of mixed-mode operation. The LVT series relies on a state-of-the-art submicron BiCMOS process to provide up to a 90% reduction in static power dissipation over ABT. LVT devices solve the system need for a transparent seam between the low-voltage and 5-V secti
  • LVT-to-LVTH Conversion
    PDF, 84 Кб, Файл опубликован: 8 дек 1998
    Original LVT devices that have bus hold have been redesigned to add the High-Impedance State During Power Up and Power Down feature. Additional devices with and without bus hold have been added to the LVT product line. Design guidelines and issues related to the bus-hold features, switching characteristics, and timing requirements are discussed.
Серия: SN74LVT8986 (2)
  • Semiconductors > Logic > Specialty Logic > Boundary Scan (JTAG) Logic
На английском языке: Datasheet Texas Instruments SN74LVT8986ZGV
