Оптопары и оптореле Megawin
Datasheet Texas Instruments SN74LVT8996PW — Даташит
СерияSN74LVT8996
МодельSN74LVT8996PW
3,3 В ABT, 10-битные адресные порты сканирования, многоточечный адресный приемопередатчик TAP IEEE STD 1149.1 (JTAG) 24-TSSOP от -40 до 85
3.3-V 10-Bit Addressable Scan Ports Multidrop-Addressable IEEE Std 1149.1 (JTAG) datasheet
PDF, 1.3 Мб, Версия: A, Файл опубликован: 2 дек 1999
Pin24
Package TypePW
Industry STD TermTSSOP
Package QTY60
МаркировкаLX8996
Width (мм)4.4
Length (мм)7.8
Thickness (мм)1
Max Height (мм)1.2
Bits10
ICC @ Nom Voltage(Max)20 мА
Output Drive (IOL/IOH)(Max)64/-32 мА
Package GroupTSSOP
Package Size: mm2:W x L24TSSOP: 50 mm2: 6.4 x 7.8(TSSOP) PKG
Technology FamilyLVT
VCC(Max)3.6 В
VCC(Min)2.7 В
  • LVT Family Characteristics (Rev. A)
    PDF, 98 Кб, Версия: A, Файл опубликован: 1 мар 1998
    To address the need for a complete low-voltage interface solution, Texas Instruments has developed a new generation of logic devices capable of mixed-mode operation. The LVT series relies on a state-of-the-art submicron BiCMOS process to provide up to a 90% reduction in static power dissipation over ABT. LVT devices solve the system need for a transparent seam between the low-voltage and 5-V secti
  • LVT-to-LVTH Conversion
    PDF, 84 Кб, Файл опубликован: 8 дек 1998
    Original LVT devices that have bus hold have been redesigned to add the High-Impedance State During Power Up and Power Down feature. Additional devices with and without bus hold have been added to the LVT product line. Design guidelines and issues related to the bus-hold features, switching characteristics, and timing requirements are discussed.
  • Semiconductors > Logic > Specialty Logic > Boundary Scan (JTAG) Logic
На английском языке: Datasheet Texas Instruments SN74LVT8996PW
