Datasheet Texas Instruments SN74LVT8996IPWREP — Даташит
СерияSN74LVT8996-EP
МодельSN74LVT8996IPWREP
Усовершенствованный продукт 3,3-В около 10-битный многоточечный приемопередатчик Ieee Std 1149.1 Tap 24-TSSOP от -40 до 85
SN74LVT8996-EP datasheet
PDF, 758 Кб, Файл опубликован: 3 сен 2003
Микросхема Логический чип, Enhanced Product 3.3V Abt 10Bit Multidrop-Addressable Ieee Std 1149.1 Tap Transceiver 24-TSSOP -40℃ to 85℃
Рутоника
SN74LVT8996IPWREP
1 012 ₽
SN74LVT8996IPWREP
1 199 ₽
SN74LVT8996IPWREP
727GS
SN74LVT8996IPWREP
Pin24
Package TypePW
Industry STD TermTSSOP
Package QTY2000
МаркировкаLT8996EP
Width (мм)4.4
Length (мм)7.8
Thickness (мм)1
Max Height (мм)1.2
Bits10
ICC @ Nom Voltage(Max)20 мА
Тип входаTTL/CMOS
Output Drive (IOL/IOH)(Max)64/-32 мА
Тип выходаLVTTL
Package GroupTSSOP
Package Size: mm2:W x L24TSSOP: 50 mm2: 6.4 x 7.8(TSSOP) PKG
RatingHiRel Enhanced Product
Technology FamilyLVT
VCC(Max)3.6 В
VCC(Min)2.7 В
  • LVT Family Characteristics (Rev. A)
    PDF, 98 Кб, Версия: A, Файл опубликован: 1 мар 1998
    To address the need for a complete low-voltage interface solution, Texas Instruments has developed a new generation of logic devices capable of mixed-mode operation. The LVT series relies on a state-of-the-art submicron BiCMOS process to provide up to a 90% reduction in static power dissipation over ABT. LVT devices solve the system need for a transparent seam between the low-voltage and 5-V secti
  • LVT-to-LVTH Conversion
    PDF, 84 Кб, Файл опубликован: 8 дек 1998
    Original LVT devices that have bus hold have been redesigned to add the High-Impedance State During Power Up and Power Down feature. Additional devices with and without bus hold have been added to the LVT product line. Design guidelines and issues related to the bus-hold features, switching characteristics, and timing requirements are discussed.
Серия: SN74LVT8996-EP (2)
  • Semiconductors > Space & High Reliability > Logic Products > Specialty Logic Products > Boundary Scan (JTAG)
На английском языке: Datasheet Texas Instruments SN74LVT8996IPWREP
Публикации по теме
