Линейка продуктов KEEN SIDE
Datasheet Texas Instruments SN74LVT8996-EP — Даташит
СерияSN74LVT8996-EP
Усовершенствованный 10-битный многоабонентский приемопередатчик стандарта IEEE Std 1149.1 с напряжением 3,3 В
SN74LVT8996-EP datasheet
PDF, 758 Кб, Файл опубликован: 3 сен 2003
SN74LVT8996IPWREPV62/04644-01YE
N12
Pin2424
Package TypePWPW
Industry STD TermTSSOPTSSOP
JEDEC CodeR-PDSO-GR-PDSO-G
Package QTY20002000
CarrierLARGE T&RLARGE T&R
МаркировкаLT8996EPLT8996EP
Width (мм)4.44.4
Length (мм)7.87.8
Thickness (мм)11
Pitch (мм).65.65
Max Height (мм)1.21.2
Parameters / ModelsSN74LVT8996IPWREP
SN74LVT8996IPWREP
V62/04644-01YE
V62/04644-01YE
Bits1010
ICC @ Nom Voltage(Max), мА2020
Тип входаTTL/CMOSTTL/CMOS
Рабочий диапазон температур, Cот -40 до 85от -40 до 85
Output Drive (IOL/IOH)(Max), мА64/-3264/-32
Тип выходаLVTTLLVTTL
Package GroupTSSOPTSSOP
Package Size: mm2:W x L, PKG24TSSOP: 50 mm2: 6.4 x 7.8(TSSOP)24TSSOP: 50 mm2: 6.4 x 7.8(TSSOP)
RatingHiRel Enhanced ProductHiRel Enhanced Product
Technology FamilyLVTLVT
VCC(Max), В3.63.6
VCC(Min), В2.72.7
RoHSСовместимСовместим
  • LVT Family Characteristics (Rev. A)
    PDF, 98 Кб, Версия: A, Файл опубликован: 1 мар 1998
    To address the need for a complete low-voltage interface solution, Texas Instruments has developed a new generation of logic devices capable of mixed-mode operation. The LVT series relies on a state-of-the-art submicron BiCMOS process to provide up to a 90% reduction in static power dissipation over ABT. LVT devices solve the system need for a transparent seam between the low-voltage and 5-V secti
  • LVT-to-LVTH Conversion
    PDF, 84 Кб, Файл опубликован: 8 дек 1998
    Original LVT devices that have bus hold have been redesigned to add the High-Impedance State During Power Up and Power Down feature. Additional devices with and without bus hold have been added to the LVT product line. Design guidelines and issues related to the bus-hold features, switching characteristics, and timing requirements are discussed.
Серия: SN74LVT8996-EP (2)
  • Semiconductors> Space & High Reliability> Logic Products> Specialty Logic Products> Boundary Scan (JTAG)
На английском языке: Datasheet Texas Instruments SN74LVT8996-EP
Публикации по теме
