Datasheet Texas Instruments SN74LVTH125-EP — Даташит
СерияSN74LVTH125-EP
Усовершенствованный продукт Четырехкратные шинные буферы Abt 3,3 В с выходами с 3 состояниями
SN74LVTH125-EP datasheet
PDF, 646 Кб, Файл опубликован: 7 ноя 2003
SN74LVTH125IPWREPV62/04671-01XE
N12
Pin1414
Package TypePWPW
Industry STD TermTSSOPTSSOP
JEDEC CodeR-PDSO-GR-PDSO-G
Package QTY20002000
CarrierLARGE T&RLARGE T&R
МаркировкаLH125EPLH125EP
Width (мм)4.44.4
Length (мм)55
Thickness (мм)11
Pitch (мм).65.65
Max Height (мм)1.21.2
Parameters / ModelsSN74LVTH125IPWREP
SN74LVTH125IPWREP
V62/04671-01XE
V62/04671-01XE
Bits44
Тип входаTTLTTL
Рабочий диапазон температур, Cот -40 до 85от -40 до 85
Тип выходаCMOSCMOS
Package GroupTSSOPTSSOP
Package Size: mm2:W x L, PKG14TSSOP: 32 mm2: 6.4 x 5(TSSOP)14TSSOP: 32 mm2: 6.4 x 5(TSSOP)
RatingHiRel Enhanced ProductHiRel Enhanced Product
Schmitt TriggerNoNo
Technology FamilyLVTLVT
VCC(Max), В3.63.6
VCC(Min), В2.72.7
Voltage(Nom), В3.33.3
RoHSСовместимСовместим
  • LVT Family Characteristics (Rev. A)
    PDF, 98 Кб, Версия: A, Файл опубликован: 1 мар 1998
    To address the need for a complete low-voltage interface solution, Texas Instruments has developed a new generation of logic devices capable of mixed-mode operation. The LVT series relies on a state-of-the-art submicron BiCMOS process to provide up to a 90% reduction in static power dissipation over ABT. LVT devices solve the system need for a transparent seam between the low-voltage and 5-V secti
  • LVT-to-LVTH Conversion
    PDF, 84 Кб, Файл опубликован: 8 дек 1998
    Original LVT devices that have bus hold have been redesigned to add the High-Impedance State During Power Up and Power Down feature. Additional devices with and without bus hold have been added to the LVT product line. Design guidelines and issues related to the bus-hold features, switching characteristics, and timing requirements are discussed.
Серия: SN74LVTH125-EP (2)
  • Semiconductors> Space & High Reliability> Logic Products> Buffers/Drivers/Transceivers> Buffer Drivers
На английском языке: Datasheet Texas Instruments SN74LVTH125-EP
Публикации по теме
