Datasheet Texas Instruments SN74LVTH162244-EP — Даташит
СерияSN74LVTH162244-EP
Усовершенствованный продукт 3.3.-V около 16-битных буферов/драйверов с выходами с 3 состояниями
SN74LVTH162244-EP datasheet
PDF, 292 Кб, Файл опубликован: 10 ноя 2003
CLVTH162244IDGGREPV62/04708-01XE
N12
Pin4848
Package TypeDGGDGG
Industry STD TermTSSOPTSSOP
JEDEC CodeR-PDSO-GR-PDSO-G
Package QTY20002000
CarrierLARGE T&RLARGE T&R
МаркировкаLH162244EPLH162244EP
Width (мм)6.16.1
Length (мм)12.512.5
Thickness (мм)1.151.15
Pitch (мм).5.5
Max Height (мм)1.21.2
Parameters / ModelsCLVTH162244IDGGREP
CLVTH162244IDGGREP
V62/04708-01XE
V62/04708-01XE
Bits1616
Тип входаTTL/CMOSTTL/CMOS
Рабочий диапазон температур, Cот -40 до 85от -40 до 85
Тип выходаLVTTLLVTTL
Package GroupTSSOPTSSOP
Package Size: mm2:W x L, PKG48TSSOP: 101 mm2: 8.1 x 12.5(TSSOP)48TSSOP: 101 mm2: 8.1 x 12.5(TSSOP)
RatingHiRel Enhanced ProductHiRel Enhanced Product
Schmitt TriggerNoNo
Technology FamilyLVTLVT
VCC(Max), В3.63.6
VCC(Min), В2.72.7
Voltage(Nom), В3.33.3
RoHSСовместимСовместим
  • LVT Family Characteristics (Rev. A)
    PDF, 98 Кб, Версия: A, Файл опубликован: 1 мар 1998
    To address the need for a complete low-voltage interface solution, Texas Instruments has developed a new generation of logic devices capable of mixed-mode operation. The LVT series relies on a state-of-the-art submicron BiCMOS process to provide up to a 90% reduction in static power dissipation over ABT. LVT devices solve the system need for a transparent seam between the low-voltage and 5-V secti
  • LVT-to-LVTH Conversion
    PDF, 84 Кб, Файл опубликован: 8 дек 1998
    Original LVT devices that have bus hold have been redesigned to add the High-Impedance State During Power Up and Power Down feature. Additional devices with and without bus hold have been added to the LVT product line. Design guidelines and issues related to the bus-hold features, switching characteristics, and timing requirements are discussed.
  • 16-Bit Widebus Logic Families in 56-Ball 0.65-mm Pitch Very Thin Fine-Pitch BGA (Rev. B)
    PDF, 895 Кб, Версия: B, Файл опубликован: 22 май 2002
Серия: SN74LVTH162244-EP (2)
  • Semiconductors> Space & High Reliability> Logic Products> Buffers/Drivers/Transceivers> Buffer Drivers
На английском языке: Datasheet Texas Instruments SN74LVTH162244-EP
Публикации по теме
