Клеммники KEEN SIDE
Datasheet Texas Instruments CLVTH162373MDLREP — Даташит
СерияSN74LVTH162373-EP
МодельCLVTH162373MDLREP
Усовершенствованный продукт, 3,3 В, около 16 бит, прозрачные защелки типа D, с выходами с 3 состояниями, 48-SSOP, от -55 до 125
SN74LVTH162373-EP datasheet
PDF, 279 Кб, Версия: A, Файл опубликован: 13 июл 2006
IC 16BIT TRANSP D-LATCH 48-SSOP. D-Type Transparent Latch 2 Channel 8:8 IC Tri-State 48-SSOP. Logic - Latches
CLVTH162373MDLREP
191 ₽
CLVTH162373MDLREP
CLVTH162373MDLREP
CLVTH162373MDLREP
Pin48
Package TypeDL
Industry STD TermSSOP
Package QTY1000
МаркировкаLVTH162373MEP
Width (мм)7.49
Length (мм)15.88
Thickness (мм)2.59
Pitch (мм).635
Max Height (мм)2.79
3-State OutputYes
Bits16
F @ Nom Voltage(Max)160 Mhz
ICC @ Nom Voltage(Max)5 мА
Тип входаTTL
Output Drive (IOL/IOH)(Max)12/-12 мА
Тип выходаTTL
Package GroupSSOP
Package Size: mm2:W x L48SSOP: 164 mm2: 10.35 x 15.88(SSOP) PKG
RatingHiRel Enhanced Product
Technology FamilyLVT
VCC(Max)3.6 В
VCC(Min)2.7 В
tpd @ Nom Voltage(Max)4.6 нс
  • LVT Family Characteristics (Rev. A)
    PDF, 98 Кб, Версия: A, Файл опубликован: 1 мар 1998
    To address the need for a complete low-voltage interface solution, Texas Instruments has developed a new generation of logic devices capable of mixed-mode operation. The LVT series relies on a state-of-the-art submicron BiCMOS process to provide up to a 90% reduction in static power dissipation over ABT. LVT devices solve the system need for a transparent seam between the low-voltage and 5-V secti
  • LVT-to-LVTH Conversion
    PDF, 84 Кб, Файл опубликован: 8 дек 1998
    Original LVT devices that have bus hold have been redesigned to add the High-Impedance State During Power Up and Power Down feature. Additional devices with and without bus hold have been added to the LVT product line. Design guidelines and issues related to the bus-hold features, switching characteristics, and timing requirements are discussed.
  • 16-Bit Widebus Logic Families in 56-Ball 0.65-mm Pitch Very Thin Fine-Pitch BGA (Rev. B)
    PDF, 895 Кб, Версия: B, Файл опубликован: 22 май 2002
Серия: SN74LVTH162373-EP (2)
  • Semiconductors > Space & High Reliability > Logic Products > Flip-Flop/Latch/Registers
На английском языке: Datasheet Texas Instruments CLVTH162373MDLREP
Публикации по теме
