Datasheet Texas Instruments SN74LVTH16241 — Даташит
СерияSN74LVTH16241
16-битные буферы/драйверы ABT 3,3 В с выходами с 3 состояниями
3.3-V ABT 16-Bit Buffers/Drivers With 3-State Outputs datasheet
PDF, 723 Кб, Версия: D, Файл опубликован: 1 ноя 2006
27 предложений от 21 поставщиков
IC BUF NON-INVERT 3.6V 48TSSOP. Buffer, Non-Inverting 4 Element 4 Bit per Element 3-State Output 48-TSSOP. Logic - Buffers, Drivers, Receivers,...
SN74LVTH16241DGGR
17 ₽
Эиком
SN74LVTH16241DLR
от 116 ₽
LifeElectronics
SN74LVTH16241DGG
SN74LVTH16241DL
SN74LVTH16241DGGRSN74LVTH16241DL
N12
Pin4848
Package TypeDGGDL
Industry STD TermTSSOPSSOP
JEDEC CodeR-PDSO-GR-PDSO-G
Package QTY200025
CarrierLARGE T&RTUBE
МаркировкаLVTH16241LVTH16241
Width (мм)6.17.49
Length (мм)12.515.88
Thickness (мм)1.152.59
Pitch (мм).5.635
Max Height (мм)1.22.79
Parameters / ModelsSN74LVTH16241DGGR
SN74LVTH16241DGGR
SN74LVTH16241DL
SN74LVTH16241DL
Bits1616
F @ Nom Voltage(Max), Mhz160160
ICC @ Nom Voltage(Max), мА0.0050.005
Рабочий диапазон температур, Cот -40 до 85от -40 до 85
Output Drive (IOL/IOH)(Max), мА-32/64-32/64
Package GroupTSSOPSSOP
Package Size: mm2:W x L, PKG48TSSOP: 101 mm2: 8.1 x 12.5(TSSOP)48SSOP: 164 mm2: 10.35 x 15.88(SSOP)
RatingCatalogCatalog
Schmitt TriggerNoNo
Technology FamilyLVTLVT
VCC(Max), В3.63.6
VCC(Min), В2.72.7
Voltage(Nom), В3.33.3
tpd @ Nom Voltage(Max), нс3.53.5
RoHSСовместимСовместим
  • LVT Family Characteristics (Rev. A)
    PDF, 98 Кб, Версия: A, Файл опубликован: 1 мар 1998
    To address the need for a complete low-voltage interface solution, Texas Instruments has developed a new generation of logic devices capable of mixed-mode operation. The LVT series relies on a state-of-the-art submicron BiCMOS process to provide up to a 90% reduction in static power dissipation over ABT. LVT devices solve the system need for a transparent seam between the low-voltage and 5-V secti
  • LVT-to-LVTH Conversion
    PDF, 84 Кб, Файл опубликован: 8 дек 1998
    Original LVT devices that have bus hold have been redesigned to add the High-Impedance State During Power Up and Power Down feature. Additional devices with and without bus hold have been added to the LVT product line. Design guidelines and issues related to the bus-hold features, switching characteristics, and timing requirements are discussed.
Серия: SN74LVTH16241 (2)
  • Semiconductors> Logic> Buffer/Driver/Transceiver> Non-Inverting Buffer/Driver
На английском языке: Datasheet Texas Instruments SN74LVTH16241
