Datasheet ТI SN74LVTH16245A-Q1 — Даташит
СерияSN74LVTH16245A-Q1
Datasheet Texas Instruments SN74LVTH16245A-Q1
Автомобильный каталог 16-битные шинные трансиверы ABT 3,3 В с выходами с 3 состояниями
3.3-V ABT 16-Bit Bus Transceiver With 3-State Outputs datasheet
PDF, 152 Кб, Версия: C, Файл опубликован: 18 янв 2008
CLVTH16245AQDGGRQ1
Статус продуктаВ производстве
CLVTH16245AQDGGRQ1
N1
Pin48
Package TypeDGG
Industry STD TermTSSOP
Package QTY2000
МаркировкаLH16245AQ1
Width (мм)6.1
Length (мм)12.5
Thickness (мм)1.15
Pitch (мм).5
Max Height (мм)1.2
Parameters / ModelsCLVTH16245AQDGGRQ1
CLVTH16245AQDGGRQ1
Bits16
F @ Nom Voltage(Max), Mhz160
ICC @ Nom Voltage(Max), мА5
Рабочий диапазон температур, Cот -40 до 125
Output Drive (IOL/IOH)(Max), мА-24/24
Package GroupTSSOP
Package Size: mm2:W x L, PKG48TSSOP: 101 mm2: 8.1 x 12.5(TSSOP)
RatingAutomotive
Schmitt TriggerNo
Technology FamilyLVT
VCC(Max), В3.6
VCC(Min), В2.7
Voltage(Nom), В3.3
tpd @ Nom Voltage(Max), нс4.5
CLVTH16245AQDGGRQ1
  • LVT Family Characteristics (Rev. A)
    PDF, 98 Кб, Версия: A, Файл опубликован: 1 мар 1998
    To address the need for a complete low-voltage interface solution, Texas Instruments has developed a new generation of logic devices capable of mixed-mode operation. The LVT series relies on a state-of-the-art submicron BiCMOS process to provide up to a 90% reduction in static power dissipation over ABT. LVT devices solve the system need for a transparent seam between the low-voltage and 5-V secti
  • LVT-to-LVTH Conversion
    PDF, 84 Кб, Файл опубликован: 8 дек 1998
    Original LVT devices that have bus hold have been redesigned to add the High-Impedance State During Power Up and Power Down feature. Additional devices with and without bus hold have been added to the LVT product line. Design guidelines and issues related to the bus-hold features, switching characteristics, and timing requirements are discussed.
  • 16-Bit Widebus Logic Families in 56-Ball 0.65-mm Pitch Very Thin Fine-Pitch BGA (Rev. B)
    PDF, 895 Кб, Версия: B, Файл опубликован: 22 май 2002
Серия: SN74LVTH16245A-Q1 (1)
  • Semiconductors> Logic> Buffer/Driver/Transceiver> Standard Transceiver
На английском языке: Datasheet Texas Instruments SN74LVTH16245A-Q1
Публикации по теме
Политика конфиденциальности
