Datasheet Texas Instruments CLVTH16373IDGGREP — Даташит
СерияSN74LVTH16373-EP
МодельCLVTH16373IDGGREP
Усовершенствованный продукт 3,3 В, около 16 бит, прозрачные защелки типа D с выходами с 3 состояниями 48-TSSOP от -40 до 85
SN74LVTH16373-EP 3.3-V ABT 16-Bit Transparent D-Type Latch With Tri-State Outputs datasheet
PDF, 945 Кб, Версия: B, Файл опубликован: 29 июн 2016
Микросхема Логический замок, Enhanced Product 3.3V Abt 16Bit Transparent D-Type Latches With 3-State Outputs 48-TSSOP -40℃ to 85℃
CLVTH16373IDGGREP
64 ₽
CLVTH16373IDGGREP
от 575 ₽
CLVTH16373IDGGREP
CLVTH16373IDGGREP
Pin48
Package TypeDGG
Industry STD TermTSSOP
Package QTY2000
МаркировкаLH16373EP
Width (мм)6.1
Length (мм)12.5
Thickness (мм)1.15
Pitch (мм).5
Max Height (мм)1.2
3-State OutputYes
Bits16
F @ Nom Voltage(Max)160 Mhz
ICC @ Nom Voltage(Max)5 мА
Тип входаTTL
Рабочий диапазон температурот -40 до 85,-55 до 125 C
Output Drive (IOL/IOH)(Max)64/-32 мА
Тип выходаTTL
Package GroupTSSOP
Package Size: mm2:W x L48TSSOP: 101 mm2: 8.1 x 12.5(TSSOP) PKG
RatingHiRel Enhanced Product
Technology FamilyLVT
VCC(Max)3.6 В
VCC(Min)2.7 В
tpd @ Nom Voltage(Max)3.8 нс
  • LVT Family Characteristics (Rev. A)
    PDF, 98 Кб, Версия: A, Файл опубликован: 1 мар 1998
    To address the need for a complete low-voltage interface solution, Texas Instruments has developed a new generation of logic devices capable of mixed-mode operation. The LVT series relies on a state-of-the-art submicron BiCMOS process to provide up to a 90% reduction in static power dissipation over ABT. LVT devices solve the system need for a transparent seam between the low-voltage and 5-V secti
  • LVT-to-LVTH Conversion
    PDF, 84 Кб, Файл опубликован: 8 дек 1998
    Original LVT devices that have bus hold have been redesigned to add the High-Impedance State During Power Up and Power Down feature. Additional devices with and without bus hold have been added to the LVT product line. Design guidelines and issues related to the bus-hold features, switching characteristics, and timing requirements are discussed.
  • 16-Bit Widebus Logic Families in 56-Ball 0.65-mm Pitch Very Thin Fine-Pitch BGA (Rev. B)
    PDF, 895 Кб, Версия: B, Файл опубликован: 22 май 2002
  • Semiconductors > Space & High Reliability > Logic Products > Flip-Flop/Latch/Registers
На английском языке: Datasheet Texas Instruments CLVTH16373IDGGREP
Публикации по теме
