Datasheet Texas Instruments SN74LVTH16652-EP — Даташит
СерияSN74LVTH16652-EP
Усовершенствованный продукт: 16-битные шинные приемопередатчики и регистры с напряжением 3,3 В около 3,3 В и выходами с 3 состояниями
SN74LVTH16652-EP datasheet
PDF, 338 Кб, Файл опубликован: 10 ноя 2003
CLVTH16652IDGGREPV62/04717-01XE
N12
Pin5656
Package TypeDGGDGG
Industry STD TermTSSOPTSSOP
JEDEC CodeR-PDSO-GR-PDSO-G
Package QTY20002000
CarrierLARGE T&RLARGE T&R
МаркировкаLH16652EPLH16652EP
Width (мм)6.16.1
Length (мм)1414
Thickness (мм)1.151.15
Pitch (мм).5.5
Max Height (мм)1.21.2
Parameters / ModelsCLVTH16652IDGGREP
CLVTH16652IDGGREP
V62/04717-01XE
V62/04717-01XE
Bits1616
Рабочий диапазон температур, Cот -40 до 85от -40 до 85
Package GroupTSSOPTSSOP
Package Size: mm2:W x L, PKG56TSSOP: 113 mm2: 8.1 x 14(TSSOP)56TSSOP: 113 mm2: 8.1 x 14(TSSOP)
RatingHiRel Enhanced ProductHiRel Enhanced Product
Schmitt TriggerNoNo
Technology FamilyLVTLVT
VCC(Max), В3.63.6
VCC(Min), В2.72.7
RoHSСовместимСовместим
  • LVT Family Characteristics (Rev. A)
    PDF, 98 Кб, Версия: A, Файл опубликован: 1 мар 1998
    To address the need for a complete low-voltage interface solution, Texas Instruments has developed a new generation of logic devices capable of mixed-mode operation. The LVT series relies on a state-of-the-art submicron BiCMOS process to provide up to a 90% reduction in static power dissipation over ABT. LVT devices solve the system need for a transparent seam between the low-voltage and 5-V secti
  • LVT-to-LVTH Conversion
    PDF, 84 Кб, Файл опубликован: 8 дек 1998
    Original LVT devices that have bus hold have been redesigned to add the High-Impedance State During Power Up and Power Down feature. Additional devices with and without bus hold have been added to the LVT product line. Design guidelines and issues related to the bus-hold features, switching characteristics, and timing requirements are discussed.
  • 16-Bit Widebus Logic Families in 56-Ball 0.65-mm Pitch Very Thin Fine-Pitch BGA (Rev. B)
    PDF, 895 Кб, Версия: B, Файл опубликован: 22 май 2002
Серия: SN74LVTH16652-EP (2)
  • Semiconductors> Space & High Reliability> Logic Products> Buffers/Drivers/Transceivers> Transceivers
На английском языке: Datasheet Texas Instruments SN74LVTH16652-EP
Публикации по теме
