Datasheet Texas Instruments SN74LVTH16835 — Даташит
СерияSN74LVTH16835
18-битные универсальные драйверы шины ABT 3,3 В с выходами с 3 состояниями
3.3-V ABT 18-Bit Universal Bus Drivers With 3-State Outputs datasheet
PDF, 1.0 Мб, Версия: C, Файл опубликован: 7 апр 1999
SN74LVTH16835DGGR
Статус продуктаВ производстве
SN74LVTH16835DGGR
N1
Pin56
Package TypeDGG
Industry STD TermTSSOP
Package QTY2000
МаркировкаLVTH16835
Width (мм)6.1
Length (мм)14
Thickness (мм)1.15
Pitch (мм).5
Max Height (мм)1.2
Parameters / ModelsSN74LVTH16835DGGR
SN74LVTH16835DGGR
F @ Nom Voltage(Max), Mhz160
ICC @ Nom Voltage(Max), мА5
Рабочий диапазон температур, Cот -40 до 85
Package GroupTSSOP
Package Size: mm2:W x L, PKG56TSSOP: 113 mm2: 8.1 x 14(TSSOP)
Schmitt TriggerNo
Technology FamilyLVT
VCC(Max), В3.6
VCC(Min), В2.7
Voltage(Nom), В2.5,3.3
tpd @ Nom Voltage(Max), нс5.1
SN74LVTH16835DGGR
  • LVT Family Characteristics (Rev. A)
    PDF, 98 Кб, Версия: A, Файл опубликован: 1 мар 1998
    To address the need for a complete low-voltage interface solution, Texas Instruments has developed a new generation of logic devices capable of mixed-mode operation. The LVT series relies on a state-of-the-art submicron BiCMOS process to provide up to a 90% reduction in static power dissipation over ABT. LVT devices solve the system need for a transparent seam between the low-voltage and 5-V secti
  • LVT-to-LVTH Conversion
    PDF, 84 Кб, Файл опубликован: 8 дек 1998
    Original LVT devices that have bus hold have been redesigned to add the High-Impedance State During Power Up and Power Down feature. Additional devices with and without bus hold have been added to the LVT product line. Design guidelines and issues related to the bus-hold features, switching characteristics, and timing requirements are discussed.
  • Bus-Hold Circuit
    PDF, 418 Кб, Файл опубликован: 5 фев 2001
    When designing systems that include CMOS devices, designers must pay special attention to the operating condition in which all of the bus drivers are in an inactive, high-impedance condition (3-state). Unless special measures are taken, this condition can lead to undefined levels and, thus, to a significant increase in the device?s power dissipation. In extreme cases, this leads to oscillation of
Серия: SN74LVTH16835 (1)
  • Semiconductors> Logic> Universal Bus Function> Universal Bus Driver (UBD)
На английском языке: Datasheet Texas Instruments SN74LVTH16835
