Линейка продуктов KEEN SIDE
Datasheet Texas Instruments 8V182512IDGGREP — Даташит
СерияSN74LVTH182512-EP
Модель8V182512IDGGREP
Усовершенствованный продукт Устройства для тестирования Abt Scan с напряжением 3,3 В с 18-разрядными приемопередатчиками универсальной шины 64-TSSOP от -40 до 85
SN74LVTH18512-EP, SN74LVTH182512-EP datasheet
PDF, 678 Кб, Файл опубликован: 10 ноя 2003
Pin64
Package TypeDGG
Industry STD TermTSSOP
Package QTY2000
МаркировкаLH182512EP
Width (мм)6.1
Length (мм)17
Thickness (мм)1.15
Pitch (мм).5
Max Height (мм)1.2
Bits18
ICC @ Nom Voltage(Max)24 мА
Тип входаTTL
Output Drive (IOL/IOH)(Max)64/-32 мА
Тип выходаTTL
Package GroupTSSOP
Package Size: mm2:W x L64TSSOP: 138 mm2: 8.1 x 17(TSSOP) PKG
RatingHiRel Enhanced Product
Technology FamilyLVT
VCC(Max)3.6 В
VCC(Min)2.7 В
tpd @ Nom Voltage(Max)5.7 нс
  • LVT Family Characteristics (Rev. A)
    PDF, 98 Кб, Версия: A, Файл опубликован: 1 мар 1998
    To address the need for a complete low-voltage interface solution, Texas Instruments has developed a new generation of logic devices capable of mixed-mode operation. The LVT series relies on a state-of-the-art submicron BiCMOS process to provide up to a 90% reduction in static power dissipation over ABT. LVT devices solve the system need for a transparent seam between the low-voltage and 5-V secti
  • LVT-to-LVTH Conversion
    PDF, 84 Кб, Файл опубликован: 8 дек 1998
    Original LVT devices that have bus hold have been redesigned to add the High-Impedance State During Power Up and Power Down feature. Additional devices with and without bus hold have been added to the LVT product line. Design guidelines and issues related to the bus-hold features, switching characteristics, and timing requirements are discussed.
  • 16-Bit Widebus Logic Families in 56-Ball 0.65-mm Pitch Very Thin Fine-Pitch BGA (Rev. B)
    PDF, 895 Кб, Версия: B, Файл опубликован: 22 май 2002
Серия: SN74LVTH182512-EP (2)
  • Semiconductors > Space & High Reliability > Logic Products > Specialty Logic Products > Boundary Scan (JTAG)
На английском языке: Datasheet Texas Instruments 8V182512IDGGREP
Публикации по теме
