Datasheet Texas Instruments SN74LVTH182512-EP — Даташит
СерияSN74LVTH182512-EP
Усовершенствованные тестовые устройства Abt Scan с напряжением 3,3 В и 18-битными универсальными шинными приемопередатчиками
SN74LVTH18512-EP, SN74LVTH182512-EP datasheet
PDF, 678 Кб, Файл опубликован: 10 ноя 2003
8V182512IDGGREPV62/04730-01XE
N12
Pin6464
Package TypeDGGDGG
Industry STD TermTSSOPTSSOP
JEDEC CodeR-PDSO-GR-PDSO-G
Package QTY20002000
CarrierLARGE T&RLARGE T&R
МаркировкаLH182512EPLH182512EP
Width (мм)6.16.1
Length (мм)1717
Thickness (мм)1.151.15
Pitch (мм).5.5
Max Height (мм)1.21.2
Parameters / Models8V182512IDGGREP
8V182512IDGGREP
V62/04730-01XE
V62/04730-01XE
Bits1818
ICC @ Nom Voltage(Max), мА2424
Тип входаTTLTTL
Рабочий диапазон температур, Cот -40 до 85от -40 до 85
Output Drive (IOL/IOH)(Max), мА64/-3264/-32
Тип выходаTTLTTL
Package GroupTSSOPTSSOP
Package Size: mm2:W x L, PKG64TSSOP: 138 mm2: 8.1 x 17(TSSOP)64TSSOP: 138 mm2: 8.1 x 17(TSSOP)
RatingHiRel Enhanced ProductHiRel Enhanced Product
Technology FamilyLVTLVT
VCC(Max), В3.63.6
VCC(Min), В2.72.7
tpd @ Nom Voltage(Max), нс5.75.7
RoHSСовместимСовместим
  • LVT Family Characteristics (Rev. A)
    PDF, 98 Кб, Версия: A, Файл опубликован: 1 мар 1998
    To address the need for a complete low-voltage interface solution, Texas Instruments has developed a new generation of logic devices capable of mixed-mode operation. The LVT series relies on a state-of-the-art submicron BiCMOS process to provide up to a 90% reduction in static power dissipation over ABT. LVT devices solve the system need for a transparent seam between the low-voltage and 5-V secti
  • LVT-to-LVTH Conversion
    PDF, 84 Кб, Файл опубликован: 8 дек 1998
    Original LVT devices that have bus hold have been redesigned to add the High-Impedance State During Power Up and Power Down feature. Additional devices with and without bus hold have been added to the LVT product line. Design guidelines and issues related to the bus-hold features, switching characteristics, and timing requirements are discussed.
  • 16-Bit Widebus Logic Families in 56-Ball 0.65-mm Pitch Very Thin Fine-Pitch BGA (Rev. B)
    PDF, 895 Кб, Версия: B, Файл опубликован: 22 май 2002
Серия: SN74LVTH182512-EP (2)
  • Semiconductors> Space & High Reliability> Logic Products> Specialty Logic Products> Boundary Scan (JTAG)
На английском языке: Datasheet Texas Instruments SN74LVTH182512-EP
Публикации по теме
