Datasheet Texas Instruments SN74LVTH18502APMR — Даташит
СерияSN74LVTH18502A
МодельSN74LVTH18502APMR
Устройства сканирования ABT 3,3 В с 18-битными приемопередатчиками универсальной шины 64-LQFP -40–85
SN54LVTH18502A, SN54LVTH182502A, SN74LVTH18502A, SN74LVTH182502A datasheet
PDF, 890 Кб, Версия: C, Файл опубликован: 3 июн 2004
Pin64
Package TypePM
Industry STD TermLQFP
JEDEC CodeS-PQFP-G
Package QTY1000
МаркировкаLVTH18502A
Width (мм)10
Length (мм)10
Thickness (мм)1.4
Pitch (мм).5
Max Height (мм)1.6
Bits18
F @ Nom Voltage(Max)160 Mhz
ICC @ Nom Voltage(Max)24 мА
Output Drive (IOL/IOH)(Max)64/-32 мА
Package GroupLQFP
Package Size: mm2:W x L64LQFP: 144 mm2: 12 x 12(LQFP) PKG
Technology FamilyLVT
VCC(Max)3.6 В
VCC(Min)2.7 В
Voltage(Nom)3.3 В
tpd @ Nom Voltage(Max)4.9 нс
  • Programming CPLDs Via the 'LVT8986 LASP
    PDF, 819 Кб, Файл опубликован: 1 ноя 2005
    This application report summarizes key information required for understanding the 'LVT8986 linking addressable scan ports (LASPs) multidrop addressable IEEE Std 1149.1 (JTAG) test access port (TAP) transceiver. This report includes information about the 'LVT8986 secondary TAPs, bypass and linking shadow protocol, scan-path description languages, serial vector format files, and an example of how to
  • LVT Family Characteristics (Rev. A)
    PDF, 98 Кб, Версия: A, Файл опубликован: 1 мар 1998
    To address the need for a complete low-voltage interface solution, Texas Instruments has developed a new generation of logic devices capable of mixed-mode operation. The LVT series relies on a state-of-the-art submicron BiCMOS process to provide up to a 90% reduction in static power dissipation over ABT. LVT devices solve the system need for a transparent seam between the low-voltage and 5-V secti
  • LVT-to-LVTH Conversion
    PDF, 84 Кб, Файл опубликован: 8 дек 1998
    Original LVT devices that have bus hold have been redesigned to add the High-Impedance State During Power Up and Power Down feature. Additional devices with and without bus hold have been added to the LVT product line. Design guidelines and issues related to the bus-hold features, switching characteristics, and timing requirements are discussed.
  • Bus-Hold Circuit
    PDF, 418 Кб, Файл опубликован: 5 фев 2001
    When designing systems that include CMOS devices, designers must pay special attention to the operating condition in which all of the bus drivers are in an inactive, high-impedance condition (3-state). Unless special measures are taken, this condition can lead to undefined levels and, thus, to a significant increase in the device?s power dissipation. In extreme cases, this leads to oscillation of
  • Semiconductors > Logic > Specialty Logic > Boundary Scan (JTAG) Logic
На английском языке: Datasheet Texas Instruments SN74LVTH18502APMR
