Линейка продуктов KEEN SIDE
Datasheet Texas Instruments SN74LVTH32244 — Даташит
СерияSN74LVTH32244
32-битный буфер/драйвер ABT 3,3 В с выходами с 3 состояниями
SN74LVTH32244 datasheet
PDF, 783 Кб, Версия: C, Файл опубликован: 1 дек 2006
SN74LVTH32244GKERSN74LVTH32244ZKER
Статус продуктаНе рекомендуется для новых разработокВ производстве
Доступность образцов у производителяДаНет
N12
Pin9696
Package TypeGKEZKE
Industry STD TermBGA MICROSTARBGA MICROSTAR
JEDEC CodeR-PBGA-NR-PBGA-N
Package QTY10001000
CarrierLARGE T&RLARGE T&R
МаркировкаHV244HV244
Width (мм)5.55.5
Length (мм)13.513.5
Thickness (мм).9.85
Pitch (мм).8.8
Max Height (мм)1.41.4
Parameters / ModelsSN74LVTH32244GKER
SN74LVTH32244GKER
SN74LVTH32244ZKER
SN74LVTH32244ZKER
Bits3232
F @ Nom Voltage(Max), Mhz160160
ICC @ Nom Voltage(Max), мА0.010.01
Рабочий диапазон температур, Cот -40 до 85от -40 до 85
Output Drive (IOL/IOH)(Max), мА-32/64-32/64
Package GroupLFBGALFBGA
Package Size: mm2:W x L, PKG96LFBGA: 74 mm2: 5.5 x 13.5(LFBGA)96LFBGA: 74 mm2: 5.5 x 13.5(LFBGA)
RatingCatalogCatalog
Schmitt TriggerNoNo
Technology FamilyLVTLVT
VCC(Max), В3.63.6
VCC(Min), В2.72.7
Voltage(Nom), В3.33.3
tpd @ Nom Voltage(Max), нс3.23.2
RoHSSee ti.comСовместим
  • LVT Family Characteristics (Rev. A)
    PDF, 98 Кб, Версия: A, Файл опубликован: 1 мар 1998
    To address the need for a complete low-voltage interface solution, Texas Instruments has developed a new generation of logic devices capable of mixed-mode operation. The LVT series relies on a state-of-the-art submicron BiCMOS process to provide up to a 90% reduction in static power dissipation over ABT. LVT devices solve the system need for a transparent seam between the low-voltage and 5-V secti
  • LVT-to-LVTH Conversion
    PDF, 84 Кб, Файл опубликован: 8 дек 1998
    Original LVT devices that have bus hold have been redesigned to add the High-Impedance State During Power Up and Power Down feature. Additional devices with and without bus hold have been added to the LVT product line. Design guidelines and issues related to the bus-hold features, switching characteristics, and timing requirements are discussed.
  • Bus-Hold Circuit
    PDF, 418 Кб, Файл опубликован: 5 фев 2001
    When designing systems that include CMOS devices, designers must pay special attention to the operating condition in which all of the bus drivers are in an inactive, high-impedance condition (3-state). Unless special measures are taken, this condition can lead to undefined levels and, thus, to a significant increase in the device?s power dissipation. In extreme cases, this leads to oscillation of
Серия: SN74LVTH32244 (2)
  • Semiconductors> Logic> Buffer/Driver/Transceiver> Non-Inverting Buffer/Driver
На английском языке: Datasheet Texas Instruments SN74LVTH32244
