Datasheet Texas Instruments SN74LVTH32244-EP — Даташит
СерияSN74LVTH32244-EP
Усовершенствованный продукт: около 3,3 В, 32-битный буфер/драйвер с выходами с 3 состояниями
SN74LVTH32244-EP (Rev. A)
PDF, 219 Кб, Версия: A, Файл опубликован: 8 июн 2004
CLVTH32244IGKEREPV62/04720-01XA
N12
Pin9696
Package TypeGKEGKE
Industry STD TermBGA MICROSTARBGA MICROSTAR
JEDEC CodeR-PBGA-NR-PBGA-N
Package QTY10001000
CarrierLARGE T&RLARGE T&R
МаркировкаL244EPL244EP
Width (мм)5.55.5
Length (мм)13.513.5
Thickness (мм).9.9
Pitch (мм).8.8
Max Height (мм)1.41.4
Parameters / ModelsCLVTH32244IGKEREPV62/04720-01XA
Bits(#)3232
Тип входаTTLTTL
Operating Temperature Range(C)-40 to 85-40 to 85
Тип выходаLVTTLLVTTL
Package GroupLFBGALFBGA
Package Size: mm2:W x L (PKG)96LFBGA: 74 mm2: 5.5 x 13.5(LFBGA)96LFBGA: 74 mm2: 5.5 x 13.5(LFBGA)
RatingHiRel Enhanced ProductHiRel Enhanced Product
Schmitt TriggerNoNo
Technology FamilyLVTLVT
VCC(Max)(V)3.63.6
VCC(Min)(V)2.72.7
Voltage(Nom)(V)3.33.3
RoHSTBDTBD
Бессвинцовая технология (Pb Free)НетНет
  • LVT Family Characteristics (Rev. A)
    PDF, 98 Кб, Версия: A, Файл опубликован: 1 мар 1998
    To address the need for a complete low-voltage interface solution, Texas Instruments has developed a new generation of logic devices capable of mixed-mode operation. The LVT series relies on a state-of-the-art submicron BiCMOS process to provide up to a 90% reduction in static power dissipation over ABT. LVT devices solve the system need for a transparent seam between the low-voltage and 5-V secti
  • LVT-to-LVTH Conversion
    PDF, 84 Кб, Файл опубликован: 8 дек 1998
    Original LVT devices that have bus hold have been redesigned to add the High-Impedance State During Power Up and Power Down feature. Additional devices with and without bus hold have been added to the LVT product line. Design guidelines and issues related to the bus-hold features, switching characteristics, and timing requirements are discussed.
  • 16-Bit Widebus Logic Families in 56-Ball 0.65-mm Pitch Very Thin Fine-Pitch BGA (Rev. B)
    PDF, 895 Кб, Версия: B, Файл опубликован: 22 май 2002
Серия: SN74LVTH32244-EP (2)
  • Semiconductors> Space & High Reliability> Logic Products> Buffers/Drivers/Transceivers> Buffer Drivers
На английском языке: Datasheet Texas Instruments SN74LVTH32244-EP
Публикации по теме
