Datasheet Texas Instruments V62/04721-01XA — Даташит
СерияSN74LVTH32373-EP
МодельV62/04721-01XA
Усовершенствованный продукт 3,3 В, около 32 бит, прозрачная защелка типа D, с выходами с 3 состояниями 96-LFBGA от -40 до 85
SN74LVTH32373-EP
PDF, 218 Кб, Файл опубликован: 10 дек 2003
Микросхема Логический замок, Enhanced Product 3.3V Abt 32Bit Transparent D-Type Latch With 3-State Outputs 96-LFBGA -40℃ to 85℃
V62/04721-01XA
289 ₽
V62/04721-01XA
293 ₽
V62/04721-01XA
LifeElectronics
V62/04721-01XA
Pin96
Package TypeGKE
Industry STD TermBGA MICROSTAR
JEDEC CodeR-PBGA-N
Package QTY1000
МаркировкаL373EP
Width (мм)5.5
Length (мм)13.5
Thickness (мм).9
Pitch (мм).8
Max Height (мм)1.4
3-State OutputYes
Bits(#)32
F @ Nom Voltage(Max)(Mhz)160
ICC @ Nom Voltage(Max)(mA)10
Тип входаTTL
LogicTrue
Operating Temperature Range(C)-40 to 85
Output Drive (IOL/IOH)(Max)(mA)64/-32
Тип выходаTTL
Package GroupLFBGA
Package Size: mm2:W x L (PKG)96LFBGA: 74 mm2: 5.5 x 13.5(LFBGA)
RatingHiRel Enhanced Product
Technology FamilyLVT
VCC(Max)(V)3.6
VCC(Min)(V)2.7
tpd @ Nom Voltage(Max)(ns)3.8
RoHSTBD
  • LVT Family Characteristics (Rev. A)
    PDF, 98 Кб, Версия: A, Файл опубликован: 1 мар 1998
    To address the need for a complete low-voltage interface solution, Texas Instruments has developed a new generation of logic devices capable of mixed-mode operation. The LVT series relies on a state-of-the-art submicron BiCMOS process to provide up to a 90% reduction in static power dissipation over ABT. LVT devices solve the system need for a transparent seam between the low-voltage and 5-V secti
  • LVT-to-LVTH Conversion
    PDF, 84 Кб, Файл опубликован: 8 дек 1998
    Original LVT devices that have bus hold have been redesigned to add the High-Impedance State During Power Up and Power Down feature. Additional devices with and without bus hold have been added to the LVT product line. Design guidelines and issues related to the bus-hold features, switching characteristics, and timing requirements are discussed.
Серия: SN74LVTH32373-EP (2)
  • Semiconductors > Space & High Reliability > Logic Products > Flip-Flop/Latch/Registers
V62/0472101XA, V62/04721 01XA
На английском языке: Datasheet Texas Instruments V62/04721-01XA
Публикации по теме
