Линейка продуктов KEEN SIDE
Datasheet Texas Instruments SN74LVTH32373-EP — Даташит
СерияSN74LVTH32373-EP
Усовершенствованный продукт, 3,3 В, 32-разрядная прозрачная защелка типа D с выходами с 3 состояниями
SN74LVTH32373-EP
PDF, 218 Кб, Файл опубликован: 10 дек 2003
CLVTH32373IGKEREPV62/04721-01XA
N12
Pin9696
Package TypeGKEGKE
Industry STD TermBGA MICROSTARBGA MICROSTAR
JEDEC CodeR-PBGA-NR-PBGA-N
Package QTY10001000
CarrierLARGE T&RLARGE T&R
МаркировкаL373EPL373EP
Width (мм)5.55.5
Length (мм)13.513.5
Thickness (мм).9.9
Pitch (мм).8.8
Max Height (мм)1.41.4
Parameters / ModelsCLVTH32373IGKEREPV62/04721-01XA
3-State OutputYesYes
Bits(#)3232
F @ Nom Voltage(Max)(Mhz)160160
ICC @ Nom Voltage(Max)(mA)1010
Тип входаTTLTTL
LogicTrueTrue
Operating Temperature Range(C)-40 to 85-40 to 85
Output Drive (IOL/IOH)(Max)(mA)64/-3264/-32
Тип выходаTTLTTL
Package GroupLFBGALFBGA
Package Size: mm2:W x L (PKG)96LFBGA: 74 mm2: 5.5 x 13.5(LFBGA)96LFBGA: 74 mm2: 5.5 x 13.5(LFBGA)
RatingHiRel Enhanced ProductHiRel Enhanced Product
Technology FamilyLVTLVT
VCC(Max)(V)3.63.6
VCC(Min)(V)2.72.7
tpd @ Nom Voltage(Max)(ns)3.83.8
RoHSTBDTBD
Бессвинцовая технология (Pb Free)НетНет
  • LVT Family Characteristics (Rev. A)
    PDF, 98 Кб, Версия: A, Файл опубликован: 1 мар 1998
    To address the need for a complete low-voltage interface solution, Texas Instruments has developed a new generation of logic devices capable of mixed-mode operation. The LVT series relies on a state-of-the-art submicron BiCMOS process to provide up to a 90% reduction in static power dissipation over ABT. LVT devices solve the system need for a transparent seam between the low-voltage and 5-V secti
  • LVT-to-LVTH Conversion
    PDF, 84 Кб, Файл опубликован: 8 дек 1998
    Original LVT devices that have bus hold have been redesigned to add the High-Impedance State During Power Up and Power Down feature. Additional devices with and without bus hold have been added to the LVT product line. Design guidelines and issues related to the bus-hold features, switching characteristics, and timing requirements are discussed.
  • 16-Bit Widebus Logic Families in 56-Ball 0.65-mm Pitch Very Thin Fine-Pitch BGA (Rev. B)
    PDF, 895 Кб, Версия: B, Файл опубликован: 22 май 2002
Серия: SN74LVTH32373-EP (2)
  • Semiconductors> Space & High Reliability> Logic Products> Flip-Flop/Latch/Registers
На английском языке: Datasheet Texas Instruments SN74LVTH32373-EP
Публикации по теме
