Datasheet Texas Instruments SN74LVTH32374 — Даташит
СерияSN74LVTH32374
32-битный триггер D-типа ABT, 3,3 В, с триггером по фронту и выходами с 3 состояниями
SN74LVTH32374 datasheet
PDF, 728 Кб, Версия: D, Файл опубликован: 10 авг 2007
27 предложений от 18 поставщиков
Микросхема Бистабильный мульти, 3.3V ABT 32Bit Edge-Triggered D-Type Flip-Flop With 3-State Outputs 96-LFBGA -40℃ to 85℃
Рутоника
SN74LVTH32374ZKER
117 ₽
SN74LVTH32374GKER
207 ₽
Эиком
SN74LVTH32374GKER
от 439 ₽
SN74LVTH32374GKER
SN74LVTH32374ZKER
Статус продуктаВ производстве
SN74LVTH32374ZKER
N1
Pin96
Package TypeZKE
Industry STD TermBGA MICROSTAR
JEDEC CodeR-PBGA-N
Package QTY1000
МаркировкаHV374
Width (мм)5.5
Length (мм)13.5
Thickness (мм).85
Pitch (мм).8
Max Height (мм)1.4
Parameters / ModelsSN74LVTH32374ZKER
SN74LVTH32374ZKER
3-State OutputYes
Bits32
F @ Nom Voltage(Max), Mhz160
ICC @ Nom Voltage(Max), мА10
Рабочий диапазон температур, Cот -40 до 85
Output Drive (IOL/IOH)(Max), мА64/-32
Package GroupLFBGA
Package Size: mm2:W x L, PKG96LFBGA: 74 mm2: 5.5 x 13.5(LFBGA)
Schmitt TriggerNo
Technology FamilyLVT
VCC(Max), В3.6
VCC(Min), В2.7
Voltage(Nom), В3.3
tpd @ Nom Voltage(Max), нс4.5
SN74LVTH32374ZKER
  • LVT Family Characteristics (Rev. A)
    PDF, 98 Кб, Версия: A, Файл опубликован: 1 мар 1998
    To address the need for a complete low-voltage interface solution, Texas Instruments has developed a new generation of logic devices capable of mixed-mode operation. The LVT series relies on a state-of-the-art submicron BiCMOS process to provide up to a 90% reduction in static power dissipation over ABT. LVT devices solve the system need for a transparent seam between the low-voltage and 5-V secti
  • LVT-to-LVTH Conversion
    PDF, 84 Кб, Файл опубликован: 8 дек 1998
    Original LVT devices that have bus hold have been redesigned to add the High-Impedance State During Power Up and Power Down feature. Additional devices with and without bus hold have been added to the LVT product line. Design guidelines and issues related to the bus-hold features, switching characteristics, and timing requirements are discussed.
  • Bus-Hold Circuit
    PDF, 418 Кб, Файл опубликован: 5 фев 2001
    When designing systems that include CMOS devices, designers must pay special attention to the operating condition in which all of the bus drivers are in an inactive, high-impedance condition (3-state). Unless special measures are taken, this condition can lead to undefined levels and, thus, to a significant increase in the device?s power dissipation. In extreme cases, this leads to oscillation of
Серия: SN74LVTH32374 (1)
  • Semiconductors> Logic> Flip-Flop/Latch/Register> D-Type Flip-Flop
На английском языке: Datasheet Texas Instruments SN74LVTH32374
