Datasheet Texas Instruments SN74LVTH32374-EP — Даташит
СерияSN74LVTH32374-EP
Усовершенствованный продукт 3,3-В около 32-битный триггер D-типа с триггером по фронту и выходами с 3 состояниями
SN74LVTH32374-EP datasheet
PDF, 220 Кб, Файл опубликован: 10 дек 2003
CLVTH32374IGKEREPV62/04722-01XA
N12
Pin9696
Package TypeGKEGKE
Industry STD TermBGA MICROSTARBGA MICROSTAR
JEDEC CodeR-PBGA-NR-PBGA-N
Package QTY10001000
CarrierLARGE T&RLARGE T&R
МаркировкаL374EPL374EP
Width (мм)5.55.5
Length (мм)13.513.5
Thickness (мм).9.9
Pitch (мм).8.8
Max Height (мм)1.41.4
Parameters / ModelsCLVTH32374IGKEREP
CLVTH32374IGKEREP
V62/04722-01XA
V62/04722-01XA
3-State OutputYesYes
Bits3232
F @ Nom Voltage(Max), Mhz160160
ICC @ Nom Voltage(Max), мА1010
Тип входаTTLTTL
Рабочий диапазон температур, Cот -40 до 85от -40 до 85
Output Drive (IOL/IOH)(Max), мА64/-3264/-32
Тип выходаTTLTTL
Package GroupLFBGALFBGA
Package Size: mm2:W x L, PKG96LFBGA: 74 mm2: 5.5 x 13.5(LFBGA)96LFBGA: 74 mm2: 5.5 x 13.5(LFBGA)
RatingHiRel Enhanced ProductHiRel Enhanced Product
Technology FamilyLVTLVT
VCC(Max), В3.63.6
VCC(Min), В2.72.7
tpd @ Nom Voltage(Max), нс4.54.5
RoHSSee ti.comSee ti.com
  • LVT Family Characteristics (Rev. A)
    PDF, 98 Кб, Версия: A, Файл опубликован: 1 мар 1998
    To address the need for a complete low-voltage interface solution, Texas Instruments has developed a new generation of logic devices capable of mixed-mode operation. The LVT series relies on a state-of-the-art submicron BiCMOS process to provide up to a 90% reduction in static power dissipation over ABT. LVT devices solve the system need for a transparent seam between the low-voltage and 5-V secti
  • LVT-to-LVTH Conversion
    PDF, 84 Кб, Файл опубликован: 8 дек 1998
    Original LVT devices that have bus hold have been redesigned to add the High-Impedance State During Power Up and Power Down feature. Additional devices with and without bus hold have been added to the LVT product line. Design guidelines and issues related to the bus-hold features, switching characteristics, and timing requirements are discussed.
  • 16-Bit Widebus Logic Families in 56-Ball 0.65-mm Pitch Very Thin Fine-Pitch BGA (Rev. B)
    PDF, 895 Кб, Версия: B, Файл опубликован: 22 май 2002
Серия: SN74LVTH32374-EP (2)
  • Semiconductors> Space & High Reliability> Logic Products> Flip-Flop/Latch/Registers
На английском языке: Datasheet Texas Instruments SN74LVTH32374-EP
Публикации по теме
