Datasheet Texas Instruments V62/04676-01XE — Даташит
Серия | SN74LVTH374-EP |
Модель | V62/04676-01XE |
Усовершенствованный продукт Восьмеричные триггеры D-типа, 3,3 В, с триггером по фронту и выходами с 3 состояниями 20-TSSOP от -40 до 85
![]() Микросхема Бистабильный мульти, Enhanced Product 3.3V Abt Octal Edge-Triggered D-Type Flip-Flops With 3-State Outputs 20-TSSOP -40℃ to 85℃ | |||
V62/04676-01XE Texas Instruments | 106 ₽ | ||
V62/04676-01XE Texas Instruments | 124 ₽ | ||
V62/04676-01XE Texas Instruments | по запросу | ||
V62/04676-01XE | по запросу |
Pin | 20 |
Package Type | PW |
Industry STD Term | TSSOP |
JEDEC Code | R-PDSO-G |
Package QTY | 2000 |
Carrier | LARGE T&R |
Маркировка | LH374EP |
Width (мм) | 4.4 |
Length (мм) | 6.5 |
Thickness (мм) | 1 |
Pitch (мм) | .65 |
Max Height (мм) | 1.2 |
Mechanical Data | Скачать |
3-State Output | Yes |
Bits | 8 |
F @ Nom Voltage(Max) | 160 Mhz |
ICC @ Nom Voltage(Max) | 5 мА |
Тип входа | TTL |
Output Drive (IOL/IOH)(Max) | 64/-32 мА |
Тип выхода | TTL |
Package Group | TSSOP |
Package Size: mm2:W x L | 20TSSOP: 42 mm2: 6.4 x 6.5(TSSOP) PKG |
Rating | HiRel Enhanced Product |
Technology Family | LVT |
VCC(Max) | 3.6 В |
VCC(Min) | 2.7 В |
tpd @ Nom Voltage(Max) | 4.5 нс |
- LVT Family Characteristics (Rev. A)PDF, 98 Кб, Версия: A, Файл опубликован: 1 мар 1998
To address the need for a complete low-voltage interface solution, Texas Instruments has developed a new generation of logic devices capable of mixed-mode operation. The LVT series relies on a state-of-the-art submicron BiCMOS process to provide up to a 90% reduction in static power dissipation over ABT. LVT devices solve the system need for a transparent seam between the low-voltage and 5-V secti - LVT-to-LVTH ConversionPDF, 84 Кб, Файл опубликован: 8 дек 1998
Original LVT devices that have bus hold have been redesigned to add the High-Impedance State During Power Up and Power Down feature. Additional devices with and without bus hold have been added to the LVT product line. Design guidelines and issues related to the bus-hold features, switching characteristics, and timing requirements are discussed.
Серия: SN74LVTH374-EP (2)
- SN74LVTH374IPWREP V62/04676-01XE
- Semiconductors > Space & High Reliability > Logic Products > Flip-Flop/Latch/Registers
V62/0467601XE, V62/04676 01XE
