Компактное аудиорешение Nuvoton NSP2340BA24E
Datasheet ТI SN74LVTH543-EP — Даташит
СерияSN74LVTH543-EP
Datasheet Texas Instruments SN74LVTH543-EP
Усовершенствованный продукт Восьмеричные зарегистрированные трансиверы Abt 3,3 В с выходами с 3 состояниями
SN74LVTH543-EP datasheet
PDF, 295 Кб, Файл опубликован: 7 ноя 2003
SN74LVTH543IPWREPV62/04677-01XE
N12
Pin2424
Package TypePWPW
Industry STD TermTSSOPTSSOP
JEDEC CodeR-PDSO-GR-PDSO-G
Package QTY20002000
CarrierLARGE T&RLARGE T&R
МаркировкаLH543EPLH543EP
Width (мм)4.44.4
Length (мм)7.87.8
Thickness (мм)11
Pitch (мм).65.65
Max Height (мм)1.21.2
Parameters / ModelsSN74LVTH543IPWREP
SN74LVTH543IPWREP
V62/04677-01XE
V62/04677-01XE
Bits88
Рабочий диапазон температур, Cот -40 до 85от -40 до 85
Package GroupTSSOPTSSOP
Package Size: mm2:W x L, PKG24TSSOP: 50 mm2: 6.4 x 7.8(TSSOP)24TSSOP: 50 mm2: 6.4 x 7.8(TSSOP)
RatingHiRel Enhanced ProductHiRel Enhanced Product
Schmitt TriggerNoNo
Technology FamilyLVTLVT
VCC(Max), В3.63.6
VCC(Min), В2.72.7
RoHSСовместимСовместим
  • LVT Family Characteristics (Rev. A)
    PDF, 98 Кб, Версия: A, Файл опубликован: 1 мар 1998
    To address the need for a complete low-voltage interface solution, Texas Instruments has developed a new generation of logic devices capable of mixed-mode operation. The LVT series relies on a state-of-the-art submicron BiCMOS process to provide up to a 90% reduction in static power dissipation over ABT. LVT devices solve the system need for a transparent seam between the low-voltage and 5-V secti
  • LVT-to-LVTH Conversion
    PDF, 84 Кб, Файл опубликован: 8 дек 1998
    Original LVT devices that have bus hold have been redesigned to add the High-Impedance State During Power Up and Power Down feature. Additional devices with and without bus hold have been added to the LVT product line. Design guidelines and issues related to the bus-hold features, switching characteristics, and timing requirements are discussed.
Серия: SN74LVTH543-EP (2)
  • Semiconductors> Space & High Reliability> Logic Products> Buffers/Drivers/Transceivers> Transceivers
На английском языке: Datasheet Texas Instruments SN74LVTH543-EP
Публикации по теме
Политика конфиденциальности
