Оптопары и оптореле Megawin
Datasheet Texas Instruments SN74LVTH573IPWREP — Даташит
СерияSN74LVTH573-EP
МодельSN74LVTH573IPWREP
Усовершенствованное изделие, 3,3 В, восьмеричные прозрачные защелки типа D, с выходами с 3 состояниями, 20-TSSOP от -40 до 85
SN74LVTH573-EP datasheet
PDF, 652 Кб, Файл опубликован: 7 ноя 2003
Pin20
Package TypePW
Industry STD TermTSSOP
Package QTY2000
МаркировкаLH573EP
Width (мм)4.4
Length (мм)6.5
Thickness (мм)1
Max Height (мм)1.2
3-State OutputYes
Bits8
F @ Nom Voltage(Max)160 Mhz
ICC @ Nom Voltage(Max)5 мА
Тип входаTTL
Output Drive (IOL/IOH)(Max)64/-32 мА
Тип выходаTTL
Package GroupTSSOP
RatingHiRel Enhanced Product
Technology FamilyLVT
VCC(Max)3.6 В
VCC(Min)2.7 В
tpd @ Nom Voltage(Max)3.9 нс
  • LVT Family Characteristics (Rev. A)
    PDF, 98 Кб, Версия: A, Файл опубликован: 1 мар 1998
    To address the need for a complete low-voltage interface solution, Texas Instruments has developed a new generation of logic devices capable of mixed-mode operation. The LVT series relies on a state-of-the-art submicron BiCMOS process to provide up to a 90% reduction in static power dissipation over ABT. LVT devices solve the system need for a transparent seam between the low-voltage and 5-V secti
  • LVT-to-LVTH Conversion
    PDF, 84 Кб, Файл опубликован: 8 дек 1998
    Original LVT devices that have bus hold have been redesigned to add the High-Impedance State During Power Up and Power Down feature. Additional devices with and without bus hold have been added to the LVT product line. Design guidelines and issues related to the bus-hold features, switching characteristics, and timing requirements are discussed.
Серия: SN74LVTH573-EP (2)
  • Semiconductors > Space & High Reliability > Logic Products > Flip-Flop/Latch/Registers
На английском языке: Datasheet Texas Instruments SN74LVTH573IPWREP
Публикации по теме
