Datasheet Texas Instruments SN74LVTH573-EP — Даташит
СерияSN74LVTH573-EP
Усовершенствованный продукт, 3,3 В, восьмеричные прозрачные защелки типа D Abt с выходами с 3 состояниями
SN74LVTH573-EP datasheet
PDF, 652 Кб, Файл опубликован: 7 ноя 2003
SN74LVTH573IPWREPV62/04678-01XE
N12
Pin2020
Package TypePWPW
Industry STD TermTSSOPTSSOP
JEDEC CodeR-PDSO-GR-PDSO-G
Package QTY20002000
CarrierLARGE T&RLARGE T&R
МаркировкаLH573EPLH573EP
Width (мм)4.44.4
Length (мм)6.56.5
Thickness (мм)11
Pitch (мм).65.65
Max Height (мм)1.21.2
Parameters / ModelsSN74LVTH573IPWREP
SN74LVTH573IPWREP
V62/04678-01XE
V62/04678-01XE
3-State OutputYesYes
Bits88
F @ Nom Voltage(Max), Mhz160160
ICC @ Nom Voltage(Max), мА55
Тип входаTTLTTL
Рабочий диапазон температур, Cот -40 до 85от -40 до 85
Output Drive (IOL/IOH)(Max), мА64/-3264/-32
Тип выходаTTLTTL
Package GroupTSSOPTSSOP
Package Size: mm2:W x L, PKG20TSSOP: 42 mm2: 6.4 x 6.5(TSSOP)20TSSOP: 42 mm2: 6.4 x 6.5(TSSOP)
RatingHiRel Enhanced ProductHiRel Enhanced Product
Technology FamilyLVTLVT
VCC(Max), В3.63.6
VCC(Min), В2.72.7
tpd @ Nom Voltage(Max), нс3.93.9
RoHSСовместимСовместим
  • LVT Family Characteristics (Rev. A)
    PDF, 98 Кб, Версия: A, Файл опубликован: 1 мар 1998
    To address the need for a complete low-voltage interface solution, Texas Instruments has developed a new generation of logic devices capable of mixed-mode operation. The LVT series relies on a state-of-the-art submicron BiCMOS process to provide up to a 90% reduction in static power dissipation over ABT. LVT devices solve the system need for a transparent seam between the low-voltage and 5-V secti
  • LVT-to-LVTH Conversion
    PDF, 84 Кб, Файл опубликован: 8 дек 1998
    Original LVT devices that have bus hold have been redesigned to add the High-Impedance State During Power Up and Power Down feature. Additional devices with and without bus hold have been added to the LVT product line. Design guidelines and issues related to the bus-hold features, switching characteristics, and timing requirements are discussed.
Серия: SN74LVTH573-EP (2)
  • Semiconductors> Space & High Reliability> Logic Products> Flip-Flop/Latch/Registers
На английском языке: Datasheet Texas Instruments SN74LVTH573-EP
Публикации по теме
