Datasheet Texas Instruments SN74SSTV32852GKFR — Даташит
| Серия | SN74SSTV32852 |
| Модель | SN74SSTV32852GKFR |
Регистровый буфер от 24 до 48 бит с входами и выходами SSTL_2 114-BGA MICROSTAR от 0 до 70
SN74SSTV32852 datasheet
PDF, 427 Кб, Версия: C, Файл опубликован: 5 фев 2003
Купить SN74SSTV32852GKFR на РадиоЛоцман.Цены — от 518 до 2 292 ₽15 предложений от 15 поставщиков IC BUFFER 24BIT-48BIT 114LFBGA. Registered Buffer with SSTL_2 Compatible I/O for DDR IC 114-BGA MICROSTAR (16x5.5). Logic - Specialty Logic | |||
| SN74SSTV32852GKFR Texas Instruments | 578 ₽ | ||
| SN74SSTV32852GKFR Texas Instruments | 2 133 ₽ | ||
| SN74SSTV32852GKFR Texas Instruments | по запросу | ||
| Pin | 114 |
| Package Type | GKF |
| Industry STD Term | BGA MICROSTAR |
| JEDEC Code | R-PBGA-N |
| Package QTY | 1000 |
| Carrier | LARGE T&R |
| Маркировка | SV852 |
| Width (мм) | 5.5 |
| Length (мм) | 16 |
| Thickness (мм) | .9 |
| Pitch (мм) | .8 |
| Max Height (мм) | 1.4 |
| Mechanical Data | Скачать |
| Количество выходов | 48 |
| Рабочий диапазон температур | от 0 до 70 C |
| Output Drive | 20 мА |
| Package Group | BGA MICROSTAR |
| Package Size: mm2:W x L | 114BGA MICROSTAR: 88 mm2: 5.5 x 16(BGA MICROSTAR) PKG |
| Rating | Catalog |
| VCC | 2.5 В |
| RoHS | See ti.com |
- 56-Pin Quad Flatpack No-Lead Logic PackagePDF, 275 Кб, Файл опубликован: 7 фев 2003
Texas Instruments (TI) Quad Flatpack No-Lead (QFN) 56-terminal package complies with JEDEC standard MO-220, allows for board miniaturization, and holds several advantages over traditional SOIC, TQFP, TSSOP, and TVSOP packaging. This package, designated RGQ by TI, physically is smaller than traditional leaded solutions, has a smaller routing area, improved thermal performance, and improved electric - Application of the SN74SSTV32852 in Stacked, Low-Profile (1U) PC-1600/2100 DIMMsPDF, 445 Кб, Файл опубликован: 7 ноя 2001
Many memory-module manufacturers are turning to low-profile (1U) DIMM designs that significantly increase memory density in computer workstations and servers. The reduction in DIMM height consequently affects the design and layout of the boards. The stacked 1U DIMMs present a unique and challenging problem due partly to the reduction in area for mounting components and also due to the load. The TI - Application of the SN74SSTVF16857 in Planar PC2700 (DDR-333) RDIMMsPDF, 359 Кб, Файл опубликован: 10 янв 2003
The high-capacity memory modules used in servers and workstations present a complex load to the memory controller used in these high-reliability, high-performance systems. To meet the demands of stable functionality over a broad spectrum of operating environments and system timing needs, and to support data integrity, these dual in-line memory modules (DIMMs) require the use of registers in the ad - Low-Power Support Using Texas Instruments SN74SSTV16857 and SN74SSTV16859PDF, 138 Кб, Файл опубликован: 9 фев 2001
The Texas Instruments SN74SSTV16857 and SN74SSTV16859 registers support the low-power mode of the DDR-DIMM. This application report explains the low-power mode and the features of the registers that support the low-power mode. Also, the considerations that the system designer must be aware of when implementing the low-power state of a registered memory module are explained. The sequence that must
Серия: SN74SSTV32852 (3)
- HPA00023GKFR SN74SSTV32852GKFR SN74SSTV32852ZKFR
- Semiconductors > Space & High Reliability > Clock & Timing Products > Memory Interface Clock and Register
