Линейка продуктов KEEN SIDE
Datasheet Texas Instruments SN74V245-7PAG — Даташит
СерияSN74V245
МодельSN74V245-7PAG
4096 x 18 Синхронная память FIFO 64-TQFP от 0 до 70
SN74V215, SN74V225, SN74V235, SN74V245 datasheet
PDF, 604 Кб, Версия: E, Файл опубликован: 13 сен 2002
Pin64
Package TypePAG
Industry STD TermTQFP
JEDEC CodeS-PQFP-G
Package QTY160
CarrierJEDEC TRAY (10+1)
МаркировкаV245-7
Width (мм)10
Length (мм)10
Thickness (мм)1
Pitch (мм).5
Max Height (мм)1.2
Package GroupTQFP
Package Size: mm2:W x L64TQFP: 144 mm2: 12 x 12(TQFP) PKG
Schmitt TriggerNo
  • Designing With TI SN74V2x5 FIFO Programmable Flags
    PDF, 91 Кб, Файл опубликован: 14 май 2001
    Many FIFOs being released today include programmable almost-empty and almost-full flags. TI?s newly released SN74V2x5 FIFOs are functionally equivalent to devices offered by IDT and are pin-for-pin compatible. The programmable flags can be used to provide interrupt signals when used in digital signal processor (DSP) and microprocessor applications. Additional configurations use the programmable fl
  • Power-Dissipation Calculations for TI FIFO Products (Rev. A)
    PDF, 106 Кб, Версия: A, Файл опубликован: 1 мар 1996
    Low power consumption is a major advantage of TI FIFO products. Power calculations are required to meet design requirements for chip temperature and system power. This document assists component and system designers in evaluating power consumption for the ACT and ABT FIFO products. Two examples of power calculations, one for the SN74ACT3632 bi-directional CMOS FIFO and one for the BiCMOS SN74ABT36
  • Using TI FIFOs to Interface High-Speed Data Converters With TI TMS320 DSPs
    PDF, 249 Кб, Файл опубликован: 8 июн 2001
    Most high-speed data converters cannot be connected directly to a digital signal processor (DSP). The required transfer rates would tie up most of the DSP's I/O bandwidth. A FIFO is an appropriate solution for this problem because it can buffer a large block of data, and the DSP can read data from the FIFO in a burst mode. This is much more efficient compared to single reads for every sampled valu
  • Semiconductors > Logic > Flip-Flop/Latch/Register > FIFO Register
SN74V2457PAG, SN74V245 7PAG
На английском языке: Datasheet Texas Instruments SN74V245-7PAG
