Datasheet Texas Instruments SN74V293-10PZA — Даташит
СерияSN74V293
МодельSN74V293-10PZA
65536 x 18 Синхронная память FIFO 80-LQFP от 0 до 70
SN74V263, SN74V273, SN74V283, SN74V293 datasheet
PDF, 818 Кб, Версия: D, Файл опубликован: 12 фев 2003
28 предложений от 17 поставщиков
IC SYNC FIFO MEM 65536X18 80LQFP. Synchronous FIFO 1.125M (64K x 18)(128K x 9) Uni-Directional 100MHz 6.5ns 80-LQFP (14x14). Logic -...
SN74V293-10PZA
1 564 ₽
TradeElectronics
SN74V293-10PZA
SN74V293-10PZA
SUV System
SN74V293-10PZA
Pin80
Package TypePZA
Industry STD TermLQFP
JEDEC CodeS-PQFP-G
Package QTY90
CarrierJEDEC TRAY (5+1)
МаркировкаV293-10
Width (мм)14
Length (мм)14
Thickness (мм)1.4
Max Height (мм)1.6
Package GroupLQFP
Package Size: mm2:W x L80LQFP: 256 mm2: 16 x 16(LQFP) PKG
Schmitt TriggerNo
  • Design Considerations of SN74V293 FIFO in a MicroStar BGA(TM) Package (Rev. A)
    PDF, 112 Кб, Версия: A, Файл опубликован: 10 апр 2002
    Texas Instruments? near-chip-scale MicroSTAR BGA? package is gaining in popularity for applications where board space and/or weight are significant design factors. However, no less-significant design factors are those associated with electronic coupling between signal paths when leading-edge high-speed digital signals are closely spaced.With a few simple routing and trace-location consideratio
  • Power-Dissipation Calculations for TI FIFO Products (Rev. A)
    PDF, 106 Кб, Версия: A, Файл опубликован: 1 мар 1996
    Low power consumption is a major advantage of TI FIFO products. Power calculations are required to meet design requirements for chip temperature and system power. This document assists component and system designers in evaluating power consumption for the ACT and ABT FIFO products. Two examples of power calculations, one for the SN74ACT3632 bi-directional CMOS FIFO and one for the BiCMOS SN74ABT36
  • Semiconductors > Logic > Flip-Flop/Latch/Register > FIFO Register
SN74V29310PZA, SN74V293 10PZA
На английском языке: Datasheet Texas Instruments SN74V293-10PZA
