Datasheet Texas Instruments SN74VMEH22501DGG — Даташит
Серия | SN74VMEH22501 |
Модель | SN74VMEH22501DGG |
8-битный универсальный шинный трансивер и два 1-битных шинных трансивера с выходами с 3 состояниями 48-TSSOP от 0 до 85
SN74VMEH22501 datasheet
PDF, 943 Кб, Версия: F, Файл опубликован: 23 фев 2010
Pin | 48 |
Package Type | DGG |
Industry STD Term | TSSOP |
JEDEC Code | R-PDSO-G |
Package QTY | 40 |
Carrier | TUBE |
Маркировка | VMEH22501 |
Width (мм) | 6.1 |
Length (мм) | 12.5 |
Thickness (мм) | 1.15 |
Pitch (мм) | .5 |
Max Height (мм) | 1.2 |
Mechanical Data | Скачать |
Bits | 10 |
F @ Nom Voltage(Max) | 120 Mhz |
ICC @ Nom Voltage(Max) | 30 мА |
Рабочий диапазон температур | от -40 до 85,0 до 85 C |
Output Drive (IOL/IOH)(Max) | -12/12 мА |
Package Group | TSSOP |
Package Size: mm2:W x L | 48TSSOP: 101 mm2: 8.1 x 12.5(TSSOP) PKG |
Rating | Catalog |
Schmitt Trigger | No |
Technology Family | VME |
VCC(Max) | 3.45 В |
VCC(Min) | 3.15 В |
Voltage(Nom) | 3.3 В |
tpd @ Nom Voltage(Max) | 8.9 нс |
- SN74VMEH22501 Universal Bus Transceiver for the VMEbus BackplanePDF, 168 Кб, Файл опубликован: 14 май 2003
- VMEH22501 in 2eSST and Conventional VME Backplane ApplicationsPDF, 487 Кб, Файл опубликован: 7 окт 2002
VMEbus(TM), one of the most widely used backplanes in the industry, has generated numerous end products by using third-party boards, mechanical hardware, software, and backplane driver chips. The VME double-edged source-synchronous transfer (2eSST) protocol needs an I/O driver to transmit signals along the VMEbus at significantly higher speeds than those achievable with the VME64 standard. TI addr
Серия: SN74VMEH22501 (5)
- 74VMEH22501DGGRE4 SN74VMEH22501DGG SN74VMEH22501DGGR SN74VMEH22501DGVR SN74VMEH22501ZQLR
- Semiconductors > Logic > Universal Bus Function > Universal Bus Transceiver (UBT)
