Datasheet Texas Instruments SN75437ANE — Даташит
СерияSN75437A
МодельSN75437ANE
Четверные драйверы периферийных устройств 16-PDIP от 0 до 70
Quadruple Peripheral Driver datasheet
PDF, 111 Кб, Версия: B, Файл опубликован: 12 сен 2000
Pin16
Package TypeNE
Industry STD TermPDIP
JEDEC CodeR-PDIP-T
Package QTY25
МаркировкаSN75437ANE
Width (мм)6.35
Length (мм)19.8
Thickness (мм)4.57
Pitch (мм)2.54
Max Height (мм)5.08
Delay Time(Typ)1950 нс
Drivers Per Package4
Input CompatibilityCMOS,TTL
Iout/ch(Max)750 мА
Iout_off(Typ)1 uA
Output Voltage(Max)70 В
Package GroupPDIP
Peak Output Current750 мА
Switching Voltage(Max)35 В
Vol@Lowest Spec Current(Typ)140 мВ
  • Stepper Motor Driving with Peripheral Drivers (Rev. A)
    PDF, 172 Кб, Версия: A, Файл опубликован: 2 дек 2016
    This application report describes in detail how to interface stepper motors with TI peripheral drivers. Primarily, this report discusses how to connect and drive stepper motors, including the stepper motor driving patterns. Advantages and disadvantages to each stepping pattern are discussed; and logic tables, timing diagrams, and pictorial representations of each driving pattern are provided.
Серия: SN75437A (2)
  • Semiconductors > Power Management > Peripheral Driver and Actuator
На английском языке: Datasheet Texas Instruments SN75437ANE
