Datasheet Texas Instruments SN75468NSRG4 — Даташит
СерияSN75468
МодельSN75468NSRG4
Высоковольтные, сильноточные транзисторные матрицы Дарлингтона 16-SO от 0 до 70
SN7546x Darlington Transistor Arrays datasheet
PDF, 1.3 Мб, Версия: E, Файл опубликован: 28 янв 2015
Pin16
Package TypeNS
Industry STD TermSOP
Package QTY2000
МаркировкаSN75468
Width (мм)5.3
Length (мм)10.3
Thickness (мм)1.95
Max Height (мм)2
Delay Time(Typ)250 нс
Drivers Per Package7
Input CompatibilityCMOS,TTL
Iout/ch(Max)500 мА
Iout_off(Typ)50 uA
Output Voltage(Max)100 В
Package GroupSO
Package Size: mm2:W x L16SO: 80 mm2: 7.8 x 10.2(SO) PKG
Peak Output Current500 мА
Switching Voltage(Max)50 В
Vol@Lowest Spec Current(Typ)900 мВ
  • Stepper Motor Driving with Peripheral Drivers (Rev. A)
    PDF, 172 Кб, Версия: A, Файл опубликован: 2 дек 2016
    This application report describes in detail how to interface stepper motors with TI peripheral drivers. Primarily, this report discusses how to connect and drive stepper motors, including the stepper motor driving patterns. Advantages and disadvantages to each stepping pattern are discussed; and logic tables, timing diagrams, and pictorial representations of each driving pattern are provided.
  • Semiconductors > Power Management > Peripheral Driver and Actuator
На английском языке: Datasheet Texas Instruments SN75468NSRG4
