Datasheet Texas Instruments SN75469DR — Даташит
| Серия | SN75469 |
| Модель | SN75469DR |
Высоковольтные, сильноточные транзисторные матрицы Дарлингтона 16-SOIC от 0 до 70
SN7546x Darlington Transistor Arrays datasheet
PDF, 1.3 Мб, Версия: E, Файл опубликован: 28 янв 2015
Купить SN75469DR на РадиоЛоцман.Цены — от 9.67 до 91 ₽33 предложений от 15 поставщиков TRANS 7NPN DARL 100V 0.5A 16SOIC. Bipolar (BJT) Transistor Array 7 NPN Darlington 100V 500mA Surface Mount 16-SOIC. Transistors - Bipolar... | |||
| SN75469DR Texas Instruments | 26 ₽ | ||
| SN75469DR Texas Instruments | 73 ₽ | ||
| SN75469DR Texas Instruments | от 91 ₽ | ||
| SN75469DR Texas Instruments | по запросу | ||
| Pin | 16 |
| Package Type | D |
| Industry STD Term | SOIC |
| JEDEC Code | R-PDSO-G |
| Package QTY | 2500 |
| Carrier | LARGE T&R |
| Маркировка | SN75469 |
| Width (мм) | 3.91 |
| Length (мм) | 9.9 |
| Thickness (мм) | 1.58 |
| Pitch (мм) | 1.27 |
| Max Height (мм) | 1.75 |
| Mechanical Data | Скачать |
| Delay Time(Typ) | 250 нс |
| Drivers Per Package | 7 |
| Input Compatibility | CMOS |
| Iout/ch(Max) | 500 мА |
| Iout_off(Typ) | 50 uA |
| Output Voltage(Max) | 100 В |
| Package Group | SOIC |
| Package Size: mm2:W x L | 16SOIC: 59 mm2: 6 x 9.9(SOIC) PKG |
| Peak Output Current | 500 мА |
| Rating | Catalog |
| Switching Voltage(Max) | 50 В |
| Vol@Lowest Spec Current(Typ) | 900 мВ |
- Stepper Motor Driving with Peripheral Drivers (Rev. A)PDF, 172 Кб, Версия: A, Файл опубликован: 2 дек 2016
This application report describes in detail how to interface stepper motors with TI peripheral drivers. Primarily, this report discusses how to connect and drive stepper motors, including the stepper motor driving patterns. Advantages and disadvantages to each stepping pattern are discussed; and logic tables, timing diagrams, and pictorial representations of each driving pattern are provided.
Серия: SN75469 (6)
- SN75469D SN75469DE4 SN75469DG4 SN75469DR SN75469N SN75469NE4
- Semiconductors > Power Management > Peripheral Driver and Actuator
