Datasheet Texas Instruments SN75LVDS82DGG — Даташит
СерияSN75LVDS82
МодельSN75LVDS82DGG
Приемник FlatLink™ 56-TSSOP от 0 до 70
SN75LVDS82 FlatLinkв„ў Receiver datasheet
PDF, 1.5 Мб, Версия: J, Файл опубликован: 24 окт 2016
Pin56
Package TypeDGG
Industry STD TermTSSOP
Package QTY35
МаркировкаSN75LVDS82
Width (мм)6.1
Length (мм)14
Thickness (мм)1.15
Pitch (мм).5
Max Height (мм)1.2
Package GroupTSSOP
Package Size: mm2:W x L56TSSOP: 113 mm2: 8.1 x 14(TSSOP) PKG
ProtocolsChannel-Link I
Supply Voltage(s)3.3 В
  • FlatLinkв„ў Data Transmission System Using SN75LVDS83B/SN75LVDS82/SN75LVDS86A
    PDF, 333 Кб, Файл опубликован: 2 фев 2010
    This application report presents various system designs possible using the FlatLinkв„ў transmitter:SN75LVDS83B, and the FlatLinkв„ў receivers: SN75LVDS82 and SN75LVDS86A. These are low-voltagedifferential signaling (LVDS) serializer/deserializer (SerDes) devices commonly used to transmit video datato liquid crystal display (LCD) panels. The application report starts with an introduction of the F
  • Time Budgeting of the Flatlink Interface Application Report
    PDF, 99 Кб, Файл опубликован: 11 июн 1997
    This document describes the FlatLinkE point-to-point data-transmission interface that provides better than a two-to-one reduction in the number of signal lines used for synchronous parallel data-bus structures.
  • Flatlink Data Transmission System Design Overview (Rev. A)
    PDF, 127 Кб, Версия: A, Файл опубликован: 1 июн 2001
    FlatLink is a data transmission system that can provide better than a 2:1 reduction in the number of signal lines used for synchronous parallel data bus structures with no loss in data throughput. To do this, FlatLink takes single-ended data at clock rates of up to 68 MHz and increases the data signaling rate seven times up to 476 Mbps. The following report provides some design guidelinesfo
  • Semiconductors > Interface > LVDS/M-LVDS/PECL > SerDes/Channel-Link
На английском языке: Datasheet Texas Instruments SN75LVDS82DGG
