Datasheet Texas Instruments SN75LVDS83DGGG4 — Даташит
СерияSN75LVDS83
МодельSN75LVDS83DGGG4
Передатчик FlatLink™ 56-TSSOP от 0 до 70
FlatLink (tm) Transmitters datasheet
PDF, 884 Кб, Версия: I, Файл опубликован: 19 май 2009
Pin56
Package TypeDGG
Industry STD TermTSSOP
Package QTY35
МаркировкаSN75LVDS83
Width (мм)6.1
Length (мм)14
Thickness (мм)1.15
Pitch (мм).5
Max Height (мм)1.2
Рекомендуемая замена
ReplacementSN75LVDS83BDGG
Replacement CodeQ
  • Time Budgeting of the Flatlink Interface Application Report
    PDF, 99 Кб, Файл опубликован: 11 июн 1997
    This document describes the FlatLinkE point-to-point data-transmission interface that provides better than a two-to-one reduction in the number of signal lines used for synchronous parallel data-bus structures.
  • Flatlink Data Transmission System Design Overview (Rev. A)
    PDF, 127 Кб, Версия: A, Файл опубликован: 1 июн 2001
    FlatLink is a data transmission system that can provide better than a 2:1 reduction in the number of signal lines used for synchronous parallel data bus structures with no loss in data throughput. To do this, FlatLink takes single-ended data at clock rates of up to 68 MHz and increases the data signaling rate seven times up to 476 Mbps. The following report provides some design guidelinesfo
  • Semiconductors > Interface > LVDS/M-LVDS/PECL > SerDes/Channel-Link
На английском языке: Datasheet Texas Instruments SN75LVDS83DGGG4
