Datasheet Texas Instruments SN75LVDS83ZQLR — Даташит
СерияSN75LVDS83
МодельSN75LVDS83ZQLR
Передатчик FlatLink™ 52-BGA MICROSTAR JUNIOR от -10 до 70
FlatLink (tm) Transmitters datasheet
PDF, 884 Кб, Версия: I, Файл опубликован: 19 май 2009
Pin52
Package TypeZQL
Industry STD TermBGA MICROSTAR JUNIOR
JEDEC CodeR-PBGA-N
Width (мм)4.5
Length (мм)7
Thickness (мм).75
Max Height (мм)1
RoHSНе совместим
  • Time Budgeting of the Flatlink Interface Application Report
    PDF, 99 Кб, Файл опубликован: 11 июн 1997
    This document describes the FlatLinkE point-to-point data-transmission interface that provides better than a two-to-one reduction in the number of signal lines used for synchronous parallel data-bus structures.
  • Flatlink Data Transmission System Design Overview (Rev. A)
    PDF, 127 Кб, Версия: A, Файл опубликован: 1 июн 2001
    FlatLink is a data transmission system that can provide better than a 2:1 reduction in the number of signal lines used for synchronous parallel data bus structures with no loss in data throughput. To do this, FlatLink takes single-ended data at clock rates of up to 68 MHz and increases the data signaling rate seven times up to 476 Mbps. The following report provides some design guidelinesfo
  • Semiconductors > Interface > Display & Imaging SerDes > FlatLink/FPD-Link (LVDS for LCD)
На английском языке: Datasheet Texas Instruments SN75LVDS83ZQLR
