Datasheet Texas Instruments SN75LVDS86 — Даташит
СерияSN75LVDS86
Приемник FlatLink(TM)
Flatlink Receiver datasheet
PDF, 400 Кб, Версия: D, Файл опубликован: 10 май 2006
SN75LVDS86DGGSN75LVDS86DGGG4SN75LVDS86DGGR
Статус продуктаВ производствеВ производствеВ производстве
Доступность образцов у производителяНетНетНет
N123
Pin484848
Package TypeDGGDGGDGG
Industry STD TermTSSOPTSSOPTSSOP
Package QTY40402000
CarrierTUBETUBELARGE T&R
МаркировкаSN75LVDS86SN75LVDS86SN75LVDS86
Width (мм)6.16.16.1
Length (мм)12.512.512.5
Thickness (мм)1.151.151.15
Pitch (мм).5.5.5
Max Height (мм)1.21.21.2
Parameters / ModelsSN75LVDS86DGG
SN75LVDS86DGG
SN75LVDS86DGGG4
SN75LVDS86DGGG4
SN75LVDS86DGGR
SN75LVDS86DGGR
Approx. Price (US$)2.94 | 1ku
Data Throughput(Mb/s)163
Driver (RL)(Ohms)100
Number of Parallel Outputs21
Рабочий диапазон температур, Cот 0 до 70от 0 до 70
PLL Frequency(MHz)31 - 68
Package GroupTSSOPTSSOPTSSOP
Package Size: mm2:W x L, PKG48TSSOP: 101 mm2: 8.1 x 12.5(TSSOP)48TSSOP: 101 mm2: 8.1 x 12.5(TSSOP)
Package Size: mm2:W x L (PKG)48TSSOP: 101 mm2: 8.1 x 12.5(TSSOP)
ProtocolsChannel-Link IChannel-Link I
RatingCatalogCatalogCatalog
Receiver (Vth)(mV)100
Serial Data Receiver Channels3
Supply Voltage(s), В3.33.3
Supply Voltage(s)(V)3.3
  • Time Budgeting of the Flatlink Interface Application Report
    PDF, 99 Кб, Файл опубликован: 11 июн 1997
    This document describes the FlatLinkE point-to-point data-transmission interface that provides better than a two-to-one reduction in the number of signal lines used for synchronous parallel data-bus structures.
  • Flatlink Data Transmission System Design Overview (Rev. A)
    PDF, 127 Кб, Версия: A, Файл опубликован: 1 июн 2001
    FlatLink is a data transmission system that can provide better than a 2:1 reduction in the number of signal lines used for synchronous parallel data bus structures with no loss in data throughput. To do this, FlatLink takes single-ended data at clock rates of up to 68 MHz and increases the data signaling rate seven times up to 476 Mbps. The following report provides some design guidelinesfo
Серия: SN75LVDS86 (3)
  • Semiconductors> Interface> Display & Imaging SerDes> FlatLink/FPD-Link (LVDS for LCD)
На английском языке: Datasheet Texas Instruments SN75LVDS86
