Datasheet Texas Instruments TAS5342A — Даташит
СерияTAS5342A
Силовая часть цифрового стереоусилителя мощностью 100 Вт
TAS5342A 100-W Stereo Digital Amplifier Power Stage datasheet
PDF, 1.4 Мб, Версия: A, Файл опубликован: 11 ноя 2016
TAS5342ADDVTAS5342ADDVR
N12
Pin4444
Package TypeDDVDDV
Industry STD TermHTSSOPHTSSOP
JEDEC CodeR-PDSO-GR-PDSO-G
Package QTY352000
CarrierTUBELARGE T&R
МаркировкаTAS5342ATAS5342A
Width (мм)6.16.1
Length (мм)1414
Thickness (мм)1.151.15
Pitch (мм).635.635
Max Height (мм)1.21.2
Parameters / ModelsTAS5342ADDV
TAS5342ADDV
TAS5342ADDVR
TAS5342ADDVR
Audio Input TypePWMPWM
Control InterfaceHardwareHardware
Рабочий диапазон температур, Cот 0 до 70от 0 до 70
Выходная мощность, W100100
Power Stage Supply(Max), В3434
Power to Bridge Tied Load(Max), W100100
Power to Parallel Bridge Tied Load(Max), W200200
SNR, дБ110110
Speaker Channels, Max44
THD + N @ 1 kHz, %0.090.09
RoHSСовместимСовместим
  • AN-1737 Managing EMI in Class D Audio Applications (Rev. A)
    PDF, 140 Кб, Версия: A, Файл опубликован: 1 май 2013
    Electromagnetic interference (EMI) is an unwanted disturbance caused in an electrical circuit byelectromagnetic radiation emitted from an external source. The disturbance may interrupt, obstruct, orotherwise degrade the effective performance of the circuit.
  • AN-1849 An Audio Amplifier Power Supply Design (Rev. B)
    PDF, 1.9 Мб, Версия: B, Файл опубликован: 1 май 2013
    This application report provides design information for a power supply for use with our newest offering of high-performance, ultra high-fidelity audio amplifier input stage ICs.
  • Guidelines for Measuring Audio Power Amplifier Performance
    PDF, 765 Кб, Файл опубликован: 30 окт 2001
    This application note provides guidelines for measuring the date sheet parameters of Texas Instruments audio power amplifiers (APAs) using prefabricated evaluation modules (EVMs). The primary equipment used for the measurements consists of the System Two audio measurement system by Audio Precision , a digital multimeter (DMM), and a dc power supply.
Серия: TAS5342A (2)
  • Semiconductors> Audio> High-Power Audio Amplifiers (>50W)> PWM Input Class-D
На английском языке: Datasheet Texas Instruments TAS5342A
