Datasheet ТI TAS5707A — Даташит
СерияTAS5707A
Datasheet Texas Instruments TAS5707A
Цифровой стереоусилитель мощности 20 Вт с эквалайзером и DRC
20-W STEREO DIGITAL AUDIO POWER AMPLIFIER WITH EQ AND DRC, datasheet
PDF, 1.4 Мб, Версия: B, Файл опубликован: 9 ноя 2009
TAS5707APHPTAS5707APHPR
Доступность образцов у производителяДаНет
N12
Pin4848
Package TypePHPPHP
Industry STD TermHTQFPHTQFP
JEDEC CodeS-PQFP-GS-PQFP-G
Package QTY2501000
CarrierJEDEC TRAY (5+1)LARGE T&R
МаркировкаTAS5707ATAS5707A
Width (мм)77
Length (мм)77
Thickness (мм)11
Pitch (мм).5.5
Max Height (мм)1.21.2
Parameters / ModelsTAS5707APHP
TAS5707APHP
TAS5707APHPR
TAS5707APHPR
Analog Supply (V), Min3.63.6
Audio Input TypeDigitalDigital
Closed/Open LoopOpenOpen
Control InterfaceHardware,SoftwareHardware,Software
Рабочий диапазон температур, Cот 0 до 85от 0 до 85
Package GroupHTQFPHTQFP
Package Size: mm2:W x L, PKG48HTQFP: 81 mm2: 9 x 9(HTQFP)48HTQFP: 81 mm2: 9 x 9(HTQFP)
Power Stage Supply(Max), В2626
Power Stage Supply(Min), В88
Power to Bridge Tied Load(Max), W2121
RatingCatalogCatalog
Sampling Rate(Max), kHz4848
Sampling Rate(Min), kHz88
Speaker Channels, Max22
Supported Bridge Tied Load(Min), Ohms66
RoHSСовместимСовместим
  • TAS57xx Dynamic Range Control
    PDF, 324 Кб, Файл опубликован: 18 июн 2010
    This application report provides background information, general equations, and instructions for proper use of the Texas Instruments TAS57xx series Dynamic Range Control (DRC). Topics include I2C configuration, single-band and dual-band DRC, coefficient computation, device offerings, and user interface configuration.
  • AN-1737 Managing EMI in Class D Audio Applications (Rev. A)
    PDF, 140 Кб, Версия: A, Файл опубликован: 1 май 2013
    Electromagnetic interference (EMI) is an unwanted disturbance caused in an electrical circuit byelectromagnetic radiation emitted from an external source. The disturbance may interrupt, obstruct, orotherwise degrade the effective performance of the circuit.
  • AN-1849 An Audio Amplifier Power Supply Design (Rev. B)
    PDF, 1.9 Мб, Версия: B, Файл опубликован: 1 май 2013
    This application report provides design information for a power supply for use with our newest offering of high-performance, ultra high-fidelity audio amplifier input stage ICs.
  • Guidelines for Measuring Audio Power Amplifier Performance
    PDF, 765 Кб, Файл опубликован: 30 окт 2001
    This application note provides guidelines for measuring the date sheet parameters of Texas Instruments audio power amplifiers (APAs) using prefabricated evaluation modules (EVMs). The primary equipment used for the measurements consists of the System Two audio measurement system by Audio Precision , a digital multimeter (DMM), and a dc power supply.
Серия: TAS5707A (2)
  • Semiconductors> Audio> Mid-Power Audio Amplifiers (5-50W)> Digital I2S Input Class-D
На английском языке: Datasheet Texas Instruments TAS5707A
Политика конфиденциальности
