Datasheet ТI TCA6424A — Даташит
| Серия | TCA6424A |
Низковольтный 24-битный расширитель ввода-вывода I2C и SMBus
TCA6424A Low-Voltage 24-Bit I2C and SMBus I/O Expander With Interrupt Output, Reset, and Configuration Registers datasheet
PDF, 1.1 Мб, Версия: C, Файл опубликован: 24 апр 2014
| TCA6424ARGJR | |
| TCA6424ARGJR | |
| N | 1 |
| Pin | 32 |
| Package Type | RGJ |
| Industry STD Term | UQFN |
| JEDEC Code | S-PQFP-N |
| Package QTY | 3000 |
| Carrier | LARGE T&R |
| Маркировка | PH424A |
| Width (мм) | 5 |
| Length (мм) | 5 |
| Pitch (мм) | .5 |
| Max Height (мм) | .6 |
| Mechanical Data | Скачать |
| Parameters / Models | TCA6424ARGJR |
| I2C Address | 0100 01x |
| Max Frequency, kHz | 400 |
| Number of I/Os | 24 |
| Рабочий диапазон температур, C | от -40 до 85 |
| Package Group | UQFN |
| Rating | Catalog |
| VCC(Max), В | 5.5 |
| VCC(Min), В | 1.65 |
| Voltage Nodes, В | 1.8,2.7,3.3,3.6,5 |
| fSCLK(Max), МГц | 0.4 |
| TCA6424ARGJR | |
- Choosing the Correct I2C Device for New DesignsPDF, 87 Кб, Файл опубликован: 7 сен 2016
The I2C bus is a very popular and powerful bus used for communication between a single (or multiple)master and a single (or multiple) slave device. In many applications there is a potential need for moreslave devices on the bus, isolation between similar addressed slaves, or a need for more I/Os. Theseneeds can be solved with an I2C buffer, switch, and I/O expander.The application note h - Maximum Clock Frequency of I2C Bus Using RepeatersPDF, 116 Кб, Файл опубликован: 15 май 2015
TCA9617 Maximum Allowed Frequency on I2C Bus Using Repeaters - I2C Bus Pull-Up Resistor CalculationPDF, 157 Кб, Файл опубликован: 13 фев 2015
- Understanding the I2C BusPDF, 124 Кб, Файл опубликован: 30 июн 2015
Серия: TCA6424A (1)
- Semiconductors> Interface> I2C> I2C IO Expander
