Datasheet Texas Instruments TDA2HA-17 — Даташит
СерияTDA2HA-17
Процессор SoC с функцией Vision Acceleration для приложений ADAS
Datasheet
TSP
TDA2HABDQAASQ1TDA2HABDQAASRQ1TDA2HABRQAASQ1TDA2HABRQAASRQ1
Статус продуктаАнонсированАнонсированАнонсированАнонсирован
Доступность образцов у производителяНетНетНетНет
N1234
Pin625625625625
Package TypeAASAASAASAAS
Width (мм)17171717
Length (мм)17171717
Thickness (мм)2.482.392.482.39
МаркировкаTDA
Parameters / ModelsTDA2HABDQAASQ1TDA2HABDQAASRQ1TDA2HABRQAASQ1TDA2HABRQAASRQ1
ARM CPU1 ARM Cortex-A151 ARM Cortex-A151 ARM Cortex-A151 ARM Cortex-A15
ARM MHz (Max.)500
750
500
750
500
750
500
750
CAN(#)2222
Co-Processor(s)2 ARM Cortex-M42 ARM Cortex-M42 ARM Cortex-M42 ARM Cortex-M4
DSP2 C66x2 C66x2 C66x2 C66x
DSP MHz (Max.)500
750
500
750
500
750
500
750
Display Options1 HDMIOUT
3 LCD OUT
1 HDMIOUT
3 LCD OUT
1 HDMIOUT
3 LCD OUT
1 HDMIOUT
3 LCD OUT
EMAC2-port 1Gb switch
10/100/1000
2-port 1Gb switch
10/100/1000
2-port 1Gb switch
10/100/1000
2-port 1Gb switch
10/100/1000
EMIF1 DDR2
1 DDR3
1 DDR3L
1 DDR2
1 DDR3
1 DDR3L
1 DDR2
1 DDR3
1 DDR3L
1 DDR2
1 DDR3
1 DDR3L
EMIF SpeedDDR2-800
DDR3-1066
DDR2-800
DDR3-1066
DDR2-800
DDR3-1066
DDR2-800
DDR3-1066
EVE MHz650
500
650
500
650
500
650
500
Embedded Vision Engine (EVE)2222
GPIO247247247247
Hardware Accelerators1 Image Video Accelerator
2 Viterbi Decoder
Audio Tracking
2 Viterbi Decoder
Audio Tracking
2 Viterbi Decoder
Audio Tracking
2 Viterbi Decoder
Audio Tracking
I2C5555
MMC/SD1x eMMC 8b
1x SDIO 8b
1x SDIO4b
1x eMMC 8b
1x SDIO 8b
1x SDIO4b
1x eMMC 8b
1x SDIO 8b
1x SDIO4b
1x eMMC 8b
1x SDIO 8b
1x SDIO4b
McASP5555
Other On-Chip Memory2.5 MB2.5 MB2.5 MB2.5 MB
PCIe1 PCIe Gen21 PCIe Gen21 PCIe Gen21 PCIe Gen2
Package GroupFCBGAFCBGAFCBGAFCBGA
Package Size: mm2:W x L (PKG)See datasheet (FCBGA)See datasheet (FCBGA)See datasheet (FCBGA)See datasheet (FCBGA)
Pin/Package625FCBGA625FCBGA625FCBGA625FCBGA
QSPI1111
RatingAutomotiveAutomotiveAutomotiveAutomotive
SPI4444
Serial I/OI2C
UART
SPI
CAN
USB
I2C
UART
SPI
CAN
USB
I2C
UART
SPI
CAN
USB
I2C
UART
SPI
CAN
USB
UART10101010
Video Input Ports7777
Watchdog Timers1111
RoHSНе совместимСовместимНе совместимНе совместим
Бессвинцовая технология (Pb Free)НетДаНетНет
  • DSS BT656 Workaround for TDA2x
    PDF, 141 Кб, Файл опубликован: 29 мар 2016
  • TDA2x/TDA2E Performance
    PDF, 6.6 Мб, Файл опубликован: 19 июл 2016
    This application report provides information on the TDA2xx and TDA2ex device throughput performances and describes the TDA2xx and TDA2ex System-on-Chip (SoC) architecture, data path infrastructure, and constraints that affect the throughput and different optimization techniques for optimum system performance. This document also provides information on the maximum possible throughput performance of
  • ADAS Power Management
    PDF, 1.3 Мб, Файл опубликован: 7 мар 2016
  • DSS Bit Exact Output
    PDF, 115 Кб, Файл опубликован: 11 янв 2016
    The display subsystem (DSS) in TDA2xx, TDA2Ex and TDA3xx platform is used for displaying video data to external devices. But DSS can also be used as a high-speed data transfer port for any non video data. One of the basic requirements of the data transfer port is that the data that is present in the memory should not be modified before the data is sent out, which means the data sent should be bit
  • Quality of Service (QoS) Knobs for DRA74x, DRA75x & TDA2x Family of Devices (Rev. A)
    PDF, 148 Кб, Версия: A, Файл опубликован: 15 дек 2016
    This application report lists various quality-of-service (QoS) knobs that are implemented in DRA74x, DRA75x and TDA2x system-on-chip (SoC) family of devices. These QoS knobs aid to optimize overall system performance while running several concurrent application scenarios.
  • Guide to fix Perf Issues Using QoS Knobs for DRA74x, DRA75x, TDA2x & TD3x Device
    PDF, 612 Кб, Файл опубликован: 13 авг 2014
    This application report provides a methodology through which performance issues can be identified and fixed in systems using DRA74x, DRA75x, TDA2x and TDA3x family of devices.
  • A Guide to Debugging With CCS on the DRA75x, DRA74x, TDA2x and TDA3x Family of D (Rev. A)
    PDF, 3.2 Мб, Версия: A, Файл опубликован: 19 авг 2016
    Being able to look into the state of the device when an application fails to run as expected is a key enabler while debugging the application. This application report walks through the different steps required to setup the TI Code Composer Studioв„ў (CCS), as well as how to debug applications on the DRA7x, TDA2x and TDA3x family of devices. The document starts with describing basic CCS debugging tec
  • Semiconductors> Processors> Automotive Processors> TDAx ADAS SoCs
На английском языке: Datasheet Texas Instruments TDA2HA-17
