Datasheet Texas Instruments TDA2LFBTQABCRQ1 — Даташит
| Серия | TDA2LF |
| Модель | TDA2LFBTQABCRQ1 |
SoC-процессор для приложений ADAS 760-FCBGA от -40 до 125
TDA2x ADAS Applications Processor 23mm Package (ABC Package) Silicon Revision 2.0 datasheet
PDF, 6.4 Мб, Версия: C, Файл опубликован: 6 июн 2017
SOC PROCESSOR FOR ADAS APPLICATI | |||
| TDA2LFBTQABCRQ1 Texas Instruments | по запросу | ||
| Pin | 760 | 760 |
| Package Type | ABC | ABC |
| Industry STD Term | FCBGA | FCBGA |
| JEDEC Code | S-PBGA-N | S-PBGA-N |
| Package QTY | 250 | 250 |
| Carrier | LARGE T&R | LARGE T&R |
| Маркировка | TDA2LFBTQABCQ1 | TDA |
| Width (мм) | 23 | 23 |
| Length (мм) | 23 | 23 |
| Thickness (мм) | 2.39 | 2.39 |
| Pitch (мм) | .8 | .8 |
| Max Height (мм) | 2.96 | 2.96 |
| ARM CPU | 2 ARM Cortex-A15 |
| ARM MHz | 650,1176 Max. |
| CSI-2 | N/A |
| Co-Processor | 4 ARM Cortex-M4 s |
| DSP | N/A |
| Display Options | N/A |
| EMAC | 10/100/1000,2-port 1Gb switch |
| EMIF | 2 DDR2,2 DDR3,2 DDR3L |
| Graphics Acceleration | N/A |
| Hardware Accelerators | 1 Image Video Accelerator,2 Viterbi Decoder,Audio Tracking |
| MMC/SD | 1x SDIO 4b,1x SDIO 8b,1x UHSI 4b,1x eMMC 8b |
| McASP | 8 |
| Other On-Chip Memory | 2.5 MB |
| PCIe | 2 PCIe Gen3 |
| Serial I/O | I2C,UART,SPI,CAN,USB |
| Video Input Ports | N/A |
- Evaluation Modules & Boards: TDA2EVM5777
TDA2x Vision EVM Kit – Spectrum Digital (Includes CPU Board and Vision Application Board)
- DSS Bit Exact OutputPDF, 115 Кб, Файл опубликован: 11 янв 2016
The display subsystem (DSS) in TDA2xx, TDA2Ex and TDA3xx platform is used for displaying video data to external devices. But DSS can also be used as a high-speed data transfer port for any non video data. One of the basic requirements of the data transfer port is that the data that is present in the memory should not be modified before the data is sent out, which means the data sent should be bit - Quad Channel Camera Application for Surround View and CMS Camera Systems (Rev. A)PDF, 485 Кб, Версия: A, Файл опубликован: 23 авг 2016
This application report discusses in detail a reference design jointly developed between OmniVision Technologies, Inc. and Texas Instruments, Inc. It interconnects Megapixel Image Sensors with the TDA2x ADAS Applications Processor. In order to bridge long distances over coax cables, TI's FPD-Link III technology comes into play. The concept proves a method over which continuous high speed transfers - DSS BT656 Workaround for TDA2xPDF, 141 Кб, Файл опубликован: 29 мар 2016
- TDA2x/TDA2E PerformancePDF, 6.6 Мб, Файл опубликован: 19 июл 2016
This application report provides information on the TDA2xx and TDA2ex device throughput performances and describes the TDA2xx and TDA2ex System-on-Chip (SoC) architecture, data path infrastructure, and constraints that affect the throughput and different optimization techniques for optimum system performance. This document also provides information on the maximum possible throughput performance of - ADAS Power ManagementPDF, 1.3 Мб, Файл опубликован: 7 мар 2016
- A Guide to Debugging With CCS on the DRA75x, DRA74x, TDA2x and TDA3x Family of D (Rev. A)PDF, 3.2 Мб, Версия: A, Файл опубликован: 19 авг 2016
Being able to look into the state of the device when an application fails to run as expected is a key enabler while debugging the application. This application report walks through the different steps required to setup the TI Code Composer Studioв„ў (CCS), as well as how to debug applications on the DRA7x, TDA2x and TDA3x family of devices. The document starts with describing basic CCS debugging tec - Guide to fix Perf Issues Using QoS Knobs for DRA74x, DRA75x, TDA2x & TD3x DevicePDF, 612 Кб, Файл опубликован: 13 авг 2014
This application report provides a methodology through which performance issues can be identified and fixed in systems using DRA74x, DRA75x, TDA2x and TDA3x family of devices. - Quality of Service (QoS) Knobs for DRA74x, DRA75x & TDA2x Family of Devices (Rev. A)PDF, 148 Кб, Версия: A, Файл опубликован: 15 дек 2016
This application report lists various quality-of-service (QoS) knobs that are implemented in DRA74x, DRA75x and TDA2x system-on-chip (SoC) family of devices. These QoS knobs aid to optimize overall system performance while running several concurrent application scenarios. - ECC/EDC on TDAxx (Rev. A)PDF, 109 Кб, Версия: A, Файл опубликован: 5 июл 2017
TDA2x and TDA3x series of automotive processor are designed to be used in automotive safety systems. To enable safety, these processors come with error detection and correction (EDC) support for various memories. This application report provides an overview and usage description of EDC. - Optimizing DRA7xx and TDA2xx Processors for use with Video Display SERDES (Rev. A)PDF, 132 Кб, Версия: A, Файл опубликован: 14 июн 2017
The purpose of this application report is to provide guidance on configuring DRA7xx and TDA2xx processors to meet video Serializer/Deserializer (SerDes) jitter requirements. - EMIF Tools (Rev. A)PDF, 207 Кб, Версия: A, Файл опубликован: 5 июн 2017
At the center of every application is the need for memory. With limited on-chip processor memory, external memory serves as a solution for large software systems and data storage, and an unstable external memory interface can result in system failures or hinder software development. To prevent potential system level anomalies and ensure robust systems, hardware must be configured correctly and tes
Серия: TDA2LF (4)
- TDA2LFBFQABCQ1 TDA2LFBFQABCRQ1 TDA2LFBTQABCQ1 TDA2LFBTQABCRQ1
- Semiconductors > Processors > Automotive Processors > TDAx ADAS SoCs
