Datasheet Texas Instruments TDA2SGBRQABCQ1 — Даташит
СерияTDA2SG
МодельTDA2SGBRQABCQ1
Процессор SoC с многофункциональной графикой, видео и ускорением изображения для приложений ADAS 760-FCBGA от -40 до 125
TDA2x ADAS Applications Processor 23mm Package (ABC Package) Silicon Revision 2.0 datasheet
PDF, 6.4 Мб, Версия: C, Файл опубликован: 6 июн 2017
Pin760760
Package TypeABCABC
Industry STD TermFCBGAFCBGA
JEDEC CodeS-PBGA-NS-PBGA-N
Package QTY6060
CarrierEIAJ TRAY (5+1)EIAJ TRAY (5+1)
МаркировкаTDA2SGBRQABCQ1TDA
Width (мм)2323
Length (мм)2323
Thickness (мм)2.392.39
Pitch (мм).8.8
Max Height (мм)2.962.96
ARM CPU1 ARM Cortex-A15
ARM MHz750 Max.
CSI-2N/A
Co-Processor4 ARM Cortex-M4 s
DSP2 C66x
DSP MHz750 Max.
Display Options1 HDMIOUT,3 LCD OUT
EMAC10/100/1000,2-port 1Gb switch
EMIF2 DDR2,2 DDR3,2 DDR3L
Embedded Vision Engine4 EVE
Embedded Vision Engine (EVE)650 Max
Graphics Acceleration1 2D,2 3D
Hardware Accelerators1 Image Video Accelerator,2 Viterbi Decoder,Audio Tracking
MMC/SD1x SDIO 4b,1x SDIO 8b,1x UHSI 4b,1x eMMC 8b
McASP8
Other On-Chip Memory2.5 MB
PCIe2 PCIe Gen3
Serial I/OI2C,UART,SPI,CAN,USB
Video Input Ports10
  • Evaluation Modules & Boards: TDA2EVM5777
    TDA2x Vision EVM Kit – Spectrum Digital (Includes CPU Board and Vision Application Board)
  • DSS Bit Exact Output
    PDF, 115 Кб, Файл опубликован: 11 янв 2016
    The display subsystem (DSS) in TDA2xx, TDA2Ex and TDA3xx platform is used for displaying video data to external devices. But DSS can also be used as a high-speed data transfer port for any non video data. One of the basic requirements of the data transfer port is that the data that is present in the memory should not be modified before the data is sent out, which means the data sent should be bit
  • Quad Channel Camera Application for Surround View and CMS Camera Systems (Rev. A)
    PDF, 485 Кб, Версия: A, Файл опубликован: 23 авг 2016
    This application report discusses in detail a reference design jointly developed between OmniVision Technologies, Inc. and Texas Instruments, Inc. It interconnects Megapixel Image Sensors with the TDA2x ADAS Applications Processor. In order to bridge long distances over coax cables, TI's FPD-Link III technology comes into play. The concept proves a method over which continuous high speed transfers
  • DSS BT656 Workaround for TDA2x
    PDF, 141 Кб, Файл опубликован: 29 мар 2016
  • TDA2x/TDA2E Performance
    PDF, 6.6 Мб, Файл опубликован: 19 июл 2016
    This application report provides information on the TDA2xx and TDA2ex device throughput performances and describes the TDA2xx and TDA2ex System-on-Chip (SoC) architecture, data path infrastructure, and constraints that affect the throughput and different optimization techniques for optimum system performance. This document also provides information on the maximum possible throughput performance of
  • ADAS Power Management
    PDF, 1.3 Мб, Файл опубликован: 7 мар 2016
  • A Guide to Debugging With CCS on the DRA75x, DRA74x, TDA2x and TDA3x Family of D (Rev. A)
    PDF, 3.2 Мб, Версия: A, Файл опубликован: 19 авг 2016
    Being able to look into the state of the device when an application fails to run as expected is a key enabler while debugging the application. This application report walks through the different steps required to setup the TI Code Composer Studioв„ў (CCS), as well as how to debug applications on the DRA7x, TDA2x and TDA3x family of devices. The document starts with describing basic CCS debugging tec
  • Guide to fix Perf Issues Using QoS Knobs for DRA74x, DRA75x, TDA2x & TD3x Device
    PDF, 612 Кб, Файл опубликован: 13 авг 2014
    This application report provides a methodology through which performance issues can be identified and fixed in systems using DRA74x, DRA75x, TDA2x and TDA3x family of devices.
  • Quality of Service (QoS) Knobs for DRA74x, DRA75x & TDA2x Family of Devices (Rev. A)
    PDF, 148 Кб, Версия: A, Файл опубликован: 15 дек 2016
    This application report lists various quality-of-service (QoS) knobs that are implemented in DRA74x, DRA75x and TDA2x system-on-chip (SoC) family of devices. These QoS knobs aid to optimize overall system performance while running several concurrent application scenarios.
  • ECC/EDC on TDAxx (Rev. A)
    PDF, 109 Кб, Версия: A, Файл опубликован: 5 июл 2017
    TDA2x and TDA3x series of automotive processor are designed to be used in automotive safety systems. To enable safety, these processors come with error detection and correction (EDC) support for various memories. This application report provides an overview and usage description of EDC.
  • Optimizing DRA7xx and TDA2xx Processors for use with Video Display SERDES (Rev. A)
    PDF, 132 Кб, Версия: A, Файл опубликован: 14 июн 2017
    The purpose of this application report is to provide guidance on configuring DRA7xx and TDA2xx processors to meet video Serializer/Deserializer (SerDes) jitter requirements.
  • EMIF Tools (Rev. A)
    PDF, 207 Кб, Версия: A, Файл опубликован: 5 июн 2017
    At the center of every application is the need for memory. With limited on-chip processor memory, external memory serves as a solution for large software systems and data storage, and an unstable external memory interface can result in system failures or hinder software development. To prevent potential system level anomalies and ensure robust systems, hardware must be configured correctly and tes
Серия: TDA2SG (2)
  • Semiconductors > Processors > Automotive Processors > TDAx ADAS SoCs
На английском языке: Datasheet Texas Instruments TDA2SGBRQABCQ1
