Datasheet Texas Instruments TDC1000PWR — Даташит
СерияTDC1000
МодельTDC1000PWR
Аналоговый интерфейс ультразвукового датчика для измерения уровня, концентрации и расхода 28-TSSOP от -40 до 125
TDC1000 Ultrasonic Sensing Analog Front End (AFE) for Level Sensing, Flow Sensing, Concentration Sensing, and Proximity Sensing Applications datasheet
PDF, 2.3 Мб, Версия: B, Файл опубликован: 24 авг 2015
Pin28
Package TypePW
Industry STD TermTSSOP
Package QTY2500
МаркировкаTDC1000PW
Width (мм)4.4
Length (мм)9.7
Thickness (мм)1
Max Height (мм)1.2
# Input Channels2
Active Supply Current(Typ)2.74 мА
InterfaceSPI
Package GroupTSSOP
Package Size: mm2:W x L28TSSOP: 62 mm2: 6.4 x 9.7(TSSOP) PKG
Sleep Supply Current(Typ)0.61 uA
Special FeaturesTime of flight
Напряжение питания5.5 Min
  • Evaluation Modules & Boards: TDC1000-GASEVM
    Ultrasonic Sensing Gas Flow Evaluation Module
  • Evaluation Modules & Boards: TDC1000-TDC7200EVM
    Ultrasonic Sensing Water Flow/Level/Concentration Evaluation Module
  • Evaluation Modules & Boards: TDC1000-C2000EVM
    Ultrasonic Sensing for Level and Concentration Measurement Evaluation Module
  • Interleaved Short Time Measurements Using TDC7200
    PDF, 1.1 Мб, Файл опубликован: 30 окт 2015
    Time-to-digital converters are used in measuring time-of-flight in multiple end applications such as drones, range finders, machine vision, robots, etc. These end applications can either use light waves, ultrasonic waves or other technologies such as RADAR. However, in each of these cases, time-of-flight between the transmitted wave and the reflected wave provides us with dista
  • How to Select and Mount Transducers in Ultrasonic Sensing for Level Sensing and (Rev. A)
    PDF, 1.3 Мб, Версия: A, Файл опубликован: 25 ноя 2015
    Ultrasonic sensing utilizing Time Of Flight (TOF) measurement techniques are used in liquid level and fluid identification sensing in the automotive, consumer and medical markets. Ultrasonic (TOF) sensing can yield high accuracy and high reliability with low-power consumption for all of these markets. In order to achieve the best cost-to-performance combination, care must be ta
  • Measuring an RTD Sensor with the TDC1000 and TDC7200 for Ultrasonic Sensing
    PDF, 107 Кб, Файл опубликован: 9 апр 2015
    This application note describes the firmware procedure for measuring temperature via two RTD's using the TDC1000 and TDC7200. Temperature is monitored in heat meters and flow meters.
  • Ultrasonic Sensing for Fluid Identification and Contamination
    PDF, 153 Кб, Файл опубликован: 30 апр 2015
    Ultrasonic sensing utilizing Time Of Flight (TOF) measurement techniques can be used to monitor material purity/contamination levels and or to differentiate materials non-invasively. This technology has been utilized in the automotive, consumer, medical and food preparation markets worldwide. Ultrasonic (TOF) sensing can yield high accuracy with low power consumption for all of
  • Using Ultrasonic Sensing to Monitor Level in Tanks
    PDF, 5.3 Мб, Файл опубликован: 25 июл 2015
    Ultrasonic sensing Time Of Flight (TOF) measurement techniques can be utilized to measure fluid levels in tanks. Those measurements can either be done from inside or outside the wall of the tank. In automotive, industrial and even medical applications the ability to perform non-invasive measurements is driven from the target fluid's corrosiveness and/or sterile requirements. Th
  • Ultrasonic Sensing Basics for Liquid Level Sensing, Flow Sensing, and Fluid Iden (Rev. A)
    PDF, 276 Кб, Версия: A, Файл опубликован: 11 июн 2015
    Ultrasonic Sensing Basics for Liquid Level Sensing, Flow Sensing, and Fluid Identification
  • Ultrasonic Sensing for Water Flow Meters and Heat Meters
    PDF, 662 Кб, Файл опубликован: 30 апр 2015
    Ultrasonic flow meters are gaining wide usage in commercial, industrial and medical applications. Major benefits of utilizing this type of flowmeter are higher accuracy, low maintenance (no moving parts), non-invasive flow measurement, and the ability to regularly diagnose health of the meter. This application note is intended as an introduction to ultrasonic time-of-flight (TO
  • Design of Analog Interface for Ultrasonic Gas Flow Meter Sensors (Rev. A)
    PDF, 2.0 Мб, Версия: A, Файл опубликован: 27 мар 2016
    Transit-time ultrasonic gas flow meters have gained acceptance in applications for gas transferdistribution. Advantages of this technology include: wide measuring range, relatively high accuracy, goodrepeatability, negligible pressure drop, general insensitivity to liquid contaminants, insensitivity tofluctuations of the gas composition, and low maintenance.This application note covers t
Серия: TDC1000 (2)
  • Semiconductors > Sensing Products > Ultrasonic Sensing
На английском языке: Datasheet Texas Instruments TDC1000PWR
