Datasheet Texas Instruments TFP410PAPG4 — Даташит
СерияTFP410
МодельTFP410PAPG4
Передатчик/сериализатор PanelBus™ TMDS DVI, 165 МГц 64-HTQFP 0–70
TFP410 TI PanelBusв„ў Digital Transmitter datasheet
PDF, 2.9 Мб, Версия: C, Файл опубликован: 31 дек 2014
23 предложений от 13 поставщиков
IC DRIVER 3/0 64HTQFP. 3/0 Driver PanelBusTM 64-HTQFP (10x10). Interface - Drivers, Receivers, Transceivers
Рутоника
TFP410PAPG4
319 ₽
TFP410PAPG4
432 ₽
Эиком
TFP410PAPG4
от 1 160 ₽
TFP410PAPG4
Pin64
Package TypePAP
Industry STD TermHTQFP
JEDEC CodeS-PQFP-G
Package QTY160
CarrierJEDEC TRAY (10+1)
МаркировкаTFP410PAP
Width (мм)10
Length (мм)10
Thickness (мм)1
Pitch (мм).5
Max Height (мм)1.2
Device TypeTransceiver
ICC250 мА
Package GroupHTQFP
Package Size: mm2:W x L64HTQFP: 144 mm2: 12 x 12(HTQFP) PKG
Supply Voltage(s)3.3 В
  • PanelBus TFP410/TFP510 Design Notes
    PDF, 35 Кб, Файл опубликован: 18 мар 2003
    The Texas Instruments TFP410/TFP510 is one device in a family of TI PanelBusв„ў digital display products that simplifies digital display systems design by offering value-added flexibility and reliability to the system designer. The TFP410 /TFP510 is a DVI 1.0 compliant digital transmitter that supports display resolutions ranging from VGA to UXGA in 24-bit, true-color pixel format. The TFP410/
  • DVI on the Motherboard Using the TFP410
    PDF, 279 Кб, Файл опубликован: 22 авг 2003
    Digital visual interface (DVI) may be thought of as a plug in card interface with significant size and complexity. It can however, be easy to implement DVI on a motherboard using the Intel 865G chipset and the TFP410 DVI transmitter. This application brief describes some considerations for designers when implementing DVI on the 865G motherboard with the TFP410.
  • DVI FAQ
    PDF, 67 Кб, Файл опубликован: 18 мар 2003
Серия: TFP410 (2)
  • Semiconductors > Interface > HDMI/DVI/DP/MIPI (CSI/DSI) > Bridges and Transceivers
На английском языке: Datasheet Texas Instruments TFP410PAPG4
