Datasheet Texas Instruments TFP501 — Даташит
| Серия | TFP501 |
Цифровой приемник PanelBus HDCP
PanelBus(TM) HDCP Digital Receiver. datasheet
PDF, 196 Кб, Версия: C, Файл опубликован: 14 июл 2011
12 предложений от 12 поставщиков , Panel Bus HDCP Digital Receiver 100Pin HTQFP | |||
| TFP501PZP Texas Instruments | 259 ₽ | ||
| TFP501PZP | 2 079 ₽ | ||
| TFP501PZP Texas Instruments | по запросу | ||
| TFP501 | по запросу | ||
| TFP501PZP | |
| TFP501PZP | |
| N | 1 |
| Pin | 100 |
| Package Type | PZP |
| Industry STD Term | HTQFP |
| JEDEC Code | S-PQFP-G |
| Package QTY | 90 |
| Carrier | JEDEC TRAY (10+1) |
| Маркировка | TFP501PZP |
| Width (мм) | 14 |
| Length (мм) | 14 |
| Thickness (мм) | 1 |
| Pitch (мм) | .5 |
| Max Height (мм) | 1.2 |
| Mechanical Data | Скачать |
| Parameters / Models | TFP501PZP![]() |
| Device Type | Transceiver |
| ICC, мА | 400 |
| Рабочий диапазон температур, C | от 0 до 70 |
| Package Group | HTQFP |
| Package Size: mm2:W x L, PKG | 100HTQFP: 256 mm2: 16 x 16(HTQFP) |
| Rating | Catalog |
| Supply Voltage(s), В | 3.3 |
| TFP501PZP | |
- TFP501 EEPROM ConsiderationsPDF, 346 Кб, Файл опубликован: 30 июл 2003
The user has a variety of EEPROMs to select for use with the TFP501. This report describes some considerations for selecting an EEPROM for use with the TFP501. Examination of the I2C activity of the TFP501 can provide an understanding of the power on requirements for the device in test. Comparison of EEPROM activity to known results can aid in diagnosis of board problems. - TFP501/TFP403 Reference DesignPDF, 127 Кб, Файл опубликован: 18 мар 2003
The TFP501 is a DVI 1.0 compliant 165-MHz receiver incorporating HDCP (High-bandwidth Digital Content Protection) that provides a secure digital connection between a DVI transmitter and DVI receiver. - HDMI/DVI to LVDS Bridge (Rev. A)PDF, 112 Кб, Версия: A, Файл опубликован: 8 апр 2013
- DVI FAQPDF, 67 Кб, Файл опубликован: 18 мар 2003
Серия: TFP501 (1)
- Semiconductors> Interface> Display & Imaging SerDes> PanelBus (DVI)
