Datasheet Texas Instruments THS0842 — Даташит
| Серия | THS0842 |
Двухканальный 8-разрядный аналого-цифровой преобразователь (АЦП) со скоростью 40 MSPS
Dual-Input, 8-Bit, 40 MSPS, Low-Power ADC w/ Single or Dual Parallel Bus Output datasheet
PDF, 503 Кб, Версия: A, Файл опубликован: 10 авг 2000
Купить THS0842 на РадиоЛоцман.Цены — от 361 до 8 283 ₽34 предложений от 22 поставщиков Микросхема Преобразователь AD, TEXAS INSTRUMENTS THS0842IPFB Analog to Digital Converter, 8Bit, 40MSPS, Single, 3V, 3.6V, TQFP | |||
| THS0842IPFB Texas Instruments | 361 ₽ | ||
| THS0842IPFB Rochester Electronics | 986 ₽ | ||
| THS0842IPFB Texas Instruments | по запросу | ||
| THS0842IPFB | |
| THS0842IPFB | |
| N | 1 |
| Pin | 48 |
| Package Type | PFB |
| Industry STD Term | TQFP |
| JEDEC Code | S-PQFP-G |
| Package QTY | 250 |
| Carrier | JEDEC TRAY (10+1) |
| Маркировка | TJ0842 |
| Width (мм) | 7 |
| Length (мм) | 7 |
| Thickness (мм) | 1 |
| Pitch (мм) | .5 |
| Max Height (мм) | 1.2 |
| Mechanical Data | Скачать |
| Parameters / Models | THS0842IPFB![]() |
| # Input Channels | 2 |
| Analog Input BW, МГц | 600 |
| Архитектура | Pipeline |
| DNL(Max), +/-LSB | 2 |
| DNL(Typ), +/-LSB | 0.7 |
| ENOB, Bits | 6.8 |
| INL(Max), +/-LSB | 2.2 |
| INL(Typ), +/-LSB | 1.5 |
| Input Buffer | No |
| Input Range, Vp-p | 1.3 |
| Interface | Parallel CMOS |
| Рабочий диапазон температур, C | от -40 до 85 |
| Package Group | TQFP |
| Package Size: mm2:W x L, PKG | 48TQFP: 81 mm2: 9 x 9(TQFP) |
| Power Consumption(Typ), mW | 320 |
| Rating | Catalog |
| Reference Mode | Ext,Int |
| Разрешение, Bits | 8 |
| SFDR, дБ | 52 |
| SINAD, дБ | 43.3 |
| SNR, дБ | 42.7 |
| Sample Rate(Max), MSPS | 40 |
| THS0842IPFB | |
- CDCE62005 as Clock Solution for High-Speed ADCsPDF, 805 Кб, Файл опубликован: 4 сен 2008
TI has introduced a family of devices well-suited to meet the demands for high-speed ADC devices such as the ADS5527 which is capable of sampling up to 210 MSPS. To realize the full potential of these high-performance products it is imperative to provide a low phase noise clock source. The CDCE62005 clock synthesizer chip offers a real-world clocking solution to meet these stringent requirements - Phase Noise Performance and Jitter Cleaning Ability of CDCE72010PDF, 2.3 Мб, Файл опубликован: 2 июн 2008
This application report presents phase noise data taken on the CDCE72010 jitter cleaner and synchronizer PLL device. The phase noise performance of the CDCE72010 depends on the phase noise of the reference clock VCXO clock and the CDCE72010 itself. This application report shows the phase noise performance at several of the most popular CDMA frequencies. This data helps the user to choose the rig - CDCE72010 as a Clocking Solution for High-Speed Analog-to-Digital ConvertersPDF, 424 Кб, Файл опубликован: 8 июн 2008
Texas Instruments has recently introduced a family of devices suitable to meet the demands of high-speed high-IF sampling analog-to-digital converters (ADCs) such as the ADS5483 which is capable of sampling up to 135 MSPS. To realize the full potential of these high-performance devices the system must provide an extremely low phase noise clock source. The CDCE72010 clock synthesizer chip offers - Noise Analysis for High Speed Op Amps (Rev. A)PDF, 256 Кб, Версия: A, Файл опубликован: 17 янв 2005
Серия: THS0842 (1)
- Semiconductors> Data Converters> Analog-to-Digital Converters (ADCs)> High Speed ADCs (>10MSPS)
